Immaculate GTR, well looked after & serviced. Currently 95,000kms. Imported at 75,000kms in 2005 after an extensive search in Japan for one in this condition.
1000kms since full top and bottom end re-build of engine by AVO TurboWorld - just run in.
Tomei Cam wheels, Stainless Steel head gasket, strengthened Head Studs
Speed Technology surge tank & porsche hi-vol fuel pump.
Large TRUST Intercooler,
Blitz 4 inch Exhaust,
HKS Pod filters,
Blitz twin BOV,
Twin Plate Heavy Duty Button Clutch
Fully Adjustable Tein Coil Over Suspension, lowered 1.5 inches,
Race Pads & fluid,
Nexxen 225/50 16inch tyres, factory rims, strut tower brace front & back.
Kenwood MP3 player, speakers & amp.
Aust Standard immobiliser & alarm.
Blitz Timer & Digital Boost guage.
Car has run a 12.6qtr mile. Running 0.87bar.
Genuine reason for sale, first to see will buy.
$24,500 inc RWC. Car is in eastern suburbs of VIC.
Phil. 0412 950 992.
Edited by captainah
selling outright. I need the cash to fund some unexpected expenses.....open to offers at this stage (fair offers - have spend $10K on rebuild, and then $300 on hicas steering arm replacement last week at the 1000 km service post rebuild - to prep the car for sale). This car has new rings, bearings, etc etc ie full rebuild.
To answer a couple of questions I've been asked in PM & offline - tyres are in good nic, never boosted past 0.9bar (pneumatic bleed adjuster means it used to momentarily spike to around 0.93, but now have it running 0.87 - spikes to around 0.9 before settling quickly at 0.87 - safe for a GTR) - factory turbos & ECU. Car has been dynoed with 207kws at the wheels. As you can see from the qtr time - it's fast.
Edited by captainah
...and 1000 km svc & rack ends replacement (hicas warning light is being reset by the factory next friday, ready for sale). All this spent since April, only done about 1200 kms since then.
ok alignment done, but rear rack has play - so getting that replaced now (car not really drivable for the next week, but people are welcome to come and have a look anyway).
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
