Here's a picture of the coilovers i have in my R33. They came on it when it was imported so i'm lost as to how they work. The ride is very firm and i wanted to know how to soften it.
(FRONT)
I also found this little dail under the bonnet. It's numbered 1-4 and i can twist the dail around with a screwdriver. Enlarge the picture and you'll see the black+white dail, it's tiny.
So are these coilovers adjustable??? Is there a list of things i need to do to adjust them? (never had 'em before)
The rear suspension doesn't have the dails but little knobs that can be turned with a wrench, though it's a little tougher to twist them round.
Any help appreciated :laugh:
Edited by R338OY
https://www.sau.com.au/forums/topic/185256-nismo-coilovers/
They're definitely coilovers.
They are damper adjustable on the front for sure, the 1-4 dial indicates ride stiffness, and alters the valving inside the shock as to how firm or soft the suspension is. 1 will be softest, 4 will be hardest.
I'm unsure about the rears, as you may just be talking about the nut that keeps the coilover assembly together, which doesn't adjust damper or anything. Often the rear coilovers have a little dial in the same place as the front ones, or at the bottom of the shock near where it bolts on.
https://www.sau.com.au/forums/topic/185256-nismo-coilovers/#findComment-3352873
Those are definitely S-Tunes shocks. For the front you need to use a screwdriver then push them down to turn. Make sure they lock into the right number and release till it come up to the top. For the rear, just turn the knob. 1 softest 4 Hardest.
https://www.sau.com.au/forums/topic/185256-nismo-coilovers/#findComment-3355140
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
    • Nice, is there a post with the new 4" dyno curve?
