After selling my modified xr6 turbo i no longer have the pleasure of a fast car :laugh:
My R32 gts-t is in need of some major upgrading.
I was going to get a new turbo injectors and all that for it but i thought it would be a waste of money as i really want to build a bigger better engine for it.
I so far see 3 options and maybe a number 4
1) Forged rb24det
2) Forged rb25det
3) Forged rb30det
4) 350Z motor with a supercharger/turbo(Probably too expensive)
Any one got some rough ideas on the price im looking at for these options?
Not sure what turbo to go either will work that out when i decide on one of the above options
I am already budgeting $1500 for an r33 5 speed manual and clutch.
Also what work shops in Perth have done these conversions before?
Thanks for the help
https://www.sau.com.au/forums/topic/185258-building-a-new-engine-for-my-32/
rb30debt :laugh:
shouldnt cost too much
blocks go for about 500 for turbo one
need a 25 head 500-600
pistons around 1200
rods about 1000
gasket abour 250
crank $?
cams 1000
stud kits $?
jun oil pump 1k
n1 water pump about 400-500
maching under 1k
labour dunno :S
clutch not necessarily need a twin plate ross from autoclutch can just build a single plate that can just do the same as a twin plate also cheaper
box 1500
alot more other shit
turbo and gate manifold and shit about 4-5k
setup will cost 15k maybe more :S
i was gonna do this same setup but id rather spend money else where
rb30debt :laugh:
pistons around 1200
rods about 1000
gasket abour 250
crank $?
cams 1000
stud kits $?
jun oil pump 1k
maching under 1k
labour dunno :S
box 1500
like on a head unit lol ;)
if i go that route i will use the 26 head may be more expensive but fits with less modifications.
Since everyone is talking about the rb30det i guess its the most popular choice.
Yep, would be a good choice.
I had planned to do this not too long ago. I was gonna slowly build up an RB30 with the 26 head and put the best of the best into it, but my 20 decided to go before i had even started, so im just in the process of rebuilding my 20 then once that is all done ill start building the 26/30 over bout a year then just drop it in when its all done or if the 20 decides to go again :)
My power goals for now are 250 - 260rwkw will I need to go forget pistons and everything else for this?
For now mainly looking for less lag in that power range other wise i could build my rb20 up if lag didnt worry me as much.
In afew years time when the morgugae isnt killing me as much then i could probably stick some forgies in her.
rb30det with gt35/40
you could get yourself a rb30 n/a block for a carton (any more and the person selling it is crazy)
or a turbo block for about 200-300 bucks max (the advantage of a turbo block is that it already has oil and water lines for the turbo drilled into the block)
you dont have to go forgies (various combinations of rb25 pistons and rb30 or rb25 rods can get a multitude of compression ratios - eg rb25 na pistons on rb30 rods is around 9:1 i believe), and the stock rb30 rods can hold upto about 300kw (if shot peened and cleaned and balanced correctly), the rb30 crank is strong enough to hold 300kw (if not more) - probably only needs a light grind around big ends and then a linish
read the multitude of threads that are around - you can spent lots and get a hipo engine, or you can spend not much and get an engine that makes only a little less power
for your power goal buy a rb25 front cut and put that in there.
Use a GT30, or for the cheap, a highflow Rb25 turbo and with ancillaries, youll get there.
That would be the cheapest way of getting to your power level which isnt high enough to warrant a forged motor.
Rb30 is overkill for that power level
If you only want that power level just chuck a stock-ish 26 in there.
Will cost you approx ~4k for a motor.
Throw another 2k at it for some GT-SS turbos, 1k for a PowerFC, injectors, pump, and make 300rwkw sometime in the future.
If your interested in going the Rb26 route I'm waiting for XSpeed to finish off my new engine and then I'll have a stock internal 26 with GT-SS for sale. It made just over 400hp at the wheels at 1.2bar. It will need injectors, dumps and a wiring loom as I'll be using these for my new engine.
Should be somtime in the next month (October-ish).
yep that 26 with GTSS would be perfect for you... don't think he will sell it to you for 3K tho:(
3K won't buy you much... maybe a turbs upgrade for the 20... factor at least 6K for any forged motor listed here
EDIT: except a rb30et, you might score a secondhand forged package relatively cheap
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
