  • Replies 243
I think I did well to earn "Fastest Stagea," didn't I?
Fastest lap while picking up other people's knocked-over cones!
Quickest effort in getting out of the way of a fast-approaching-and-very-sideways RX7.
Oh, and my skid-pan time was 0.00.000 - beat that, everyone!!!*
*I didn't go on the skid-pan. :P
Oh I forgot one: Fastest wagon on compliance tyres and factory "offroad-height" suspension!
I won fastest around the skid pan in an apron :laughing-smiley-014:
That was awesome Nige, I remember watching you run down to the skid-pan from the BBQ to do your run, and returning in what seemed like less than 30 seconds later. I was a bit stunned! :(:):P
Hi morgs! :(
long time no post!! hahaha
James, the semi's helped no doubt, but Ive been doing quite a fair few events now on street tyres and they just get sooo screwed that its time for semi's ;)
Hi morgs! :wave:
James, the semi's helped no doubt, but Ive been doing quite a fair few events now on street tyres and they just get sooo screwed that its time for semi's :)
yeah....damn road tyres are absolutely useless LOL....but a lot more fun sliding around the corners
it would have been good to run 2 different hill climbs.that course is allot bigger than than i thought.
Steveo - did you pull that time on your first run out?
Nah, my first run was by FAR the best but the stopwatch stuffed up so it wasnt timed
That was probably the 3rd one, the 2nd one wasnt too good in one bit - i was fishtailing :wave:
only weaksauce bring semis............we real men play with road tyres and 2wd.
*runs and hides*
lol
Ill agree with you until a certain awd car is working again
BTW, did anyone get photos of my car?
Check out the guy that was taking photo's of everybody.
He had about 15 photo's of us in action, so he may have a few of you.
website is aographics.com
email is [email protected]
I won fastest car with fold up green and white striped chairs in boot award, and
voted best driver on the day that was too scared to push too hard award.
Ando you know i would've been close to you if i had cheater tyres on too.
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
