Awsome pics.
mine was the dirtiest car there. black R32 gtst. and probably didn't warrant any photos :( but if anyone has any please post em up. especially of the hill incident
I agree on that one.. 2xskidpan = dirty dirty. Mines hella dirty too. Too lazy to clean.
It gives it a good "what the f have you been doing" look when you're driving around the city.
It's like a new paint job!
  • Replies 243
Dam, what a sexy 34 4 door... looks like it didn't even have to compete to get a nice photo lol. Next time it will be though. :mellow:
anybody get pics of WTF33R?
I cleaned off the love heart off my car when i filled up, driving home with my mate we would have got wierd looks on the highway if i kept it on
I got photo's of your car Sam, as well as i think just about everyone elses on the day down at the skid pan.
My photo's are no where near the standard of the ones posted by AOGraphics, still learing even tried out the "speed" setting for a change lol.
Still uploading them to my online album theres only like 475 photos.
Yeah where are these times lol..... what are the Skyline people affraid to list them as i think there is only 1 skyline in the Top 5........ ROFLCOPTER!! :domokun:
*fingers crossed* its me? :worship:
Could be actually.... as far as i recall the Quickest went:
1. RX7 - Pfft not even a Nissan and not even road registered so doesnt count.... absolute weapon anyway....
2. White S15
3. 350Z - Drunkan 'I left 2nd gear on the back track'
4. Cefiro - Ahahah
5. R33 GTST - Chubbs 'I take 40 minutes to change 4 wheels'....
I do recall Ladybytes doing a 1:36 or something like that but took out a cone so got a 5sec penalty......
Im sure Adam will confirm the list... once he unloads his car LOL
Most photo's now uploaded will chase up the others later on:
http://lanky71.myphotoalbum.com - First album just click on the image next to it to enter.
If anyone does happen to want the original files to manipulate or have full size versions as i don't think the online album lets you do that pm me with the file name and your email address.
Drew.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
