Does anyone know if pre AU rims will fit on an R32 GTR?
If not what other non nissan stockies will fit?
Cheers
stud pattern is the same but unsure about the offset..is it only for the rears?? If it is should be no problem with caliper clearance.
Haha, yeah it is. I need as many as possible now that I have that 2wd 4wd switch.
Cheers
the offset will be wrong.
also ford wheels are shit. you are better off just getting s14/r33 wheels. they shoul fit, and are cheap.
otherwie just get some cheap second hand jap wheels from a site sponsor.
I was only going for the ford rims as they are like $20 and I need about 10 of them for the weekend (Performance car mania which is like Easternats), lots of burn out and drifting. Plus they only have to go on the rears thanks to dirtgarage and his 4wd switch.
Cheers
James
AU ones will fit, and pre-AU will also fit - EA, EB, ED, EF, EL.
Basically the EA, EB, ED, EF, EL ones wont fit on the front due to the offset, but are fine on the back.
The AU ones should fit fine on the front and clear the brakes.
