  • Replies 200
car now has:
new windscreen. (with built in Ariel)
Full Whiteline suspension package(front and rear race sway bars,front camber kit,rear upper camber arms,rear lower tow arms,rear sub frame spacer kit)
new oil catch can modifications with sump drain back.
new water overflow tank
new front pillow ball mounts
new koyo radiator
Total cost :$3500
SELLING PRICE WILL NOW BE $38000 DOLLARS
CONSIDERING THE NEW MODIFICATIONS .
Was down at the Shift Performance track day last Friday down at Wakefield park .car ran a 1:07min on worn slicks and took out fastest AWD Turbo of the day! with new slicks and more tweaking on the suspension i can see the car dipping into the low 1:06-1:05 mark and thats with me driving :D. Also put the car on the dyno down at unigroup the night before and we realed out 392 KW on 20psi with a very rich safe tune !!
come and get your selves an awesome gtr peoples going verrryyyyy cheaaaappppppppppppp !!!!!!
hey ant - u changed your exhaust to a hks hiper...was diameter exhaust did u have before & what is it running now?
it must sound awesome without mufflers ;)
hey marko
i run the hks hiper on the street and the buddyclub on the track! it sounds fantastic with the buddy club you can hear the turbos spool like crazy !!
come on guys and gals need to move the car before i head overseas!!!! make a good offer over 35k and i will do a deal !!!
i am willing to take some parts off also!
Where about in Sydney are ya n contact no , i wanna have a look at the car Thanx
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
