Hi,
i just installed my sound system....
when i turned up the to certain volume, front speaker doesn;t work...
my system has a JVC headunit with only 1 RCA preout, kenwood 4 ch 500W, front speaker is pioneer kelvar 6in slipt component, the rear speaker is Apline type S 6in.
since HU has only one RCA preout, i bought a Hi/Low converter for the front speaker
the problem is now, when i turn up volume to certain level, the front speaker stops working, the rear still work....
i have to turn off the HU, and turn down the volume, then the front speaker works again. Again when i turn volume up to certain level, front peaker stop...
what will be the problem???
Plz help.
Thx
https://www.sau.com.au/forums/topic/185309-front-speaker-problem-plz-help/
First things first, dont install it yourself if you dont what you are doing.
Second you have a short somewhere it is as simple as that, sending your product into protection most likely the amplifier.
And you dont need a hi/lo level converter if you have one rca. All you need is a couple of splitters.
Edited by Adelaideprosound
As above.. if you have a speaker-to-RCA type of converter to get a 2nd pair of RCA outputs.... don't bother =-]
My last setup (previous car) was easily done by buying two RCA splitters (10cm long) and splitting the RCA right at the amp. I didn't have any problems with interference or loss of voltage over the RCA's. It was just as if I had two sets of pre-outs. (except for having to balance front/rear via the amp)
Does it meant my Headunit do not have enough voltage for the Hi/Low convertor?
Umm.. no idea. I was just saying that if you *DO* use an RCA splitter to your 4-channel amp, you shouldn't have any problems with voltage over RCA.
If your setup wasn't working from the outset, it's worth trying this method. It'll only cost you $20-30 for the splitters and maybe an hour of your time.
