On Saturday morning I went out to QR to watch Russ and Mark test a few bits and pieces on their R32 which is being prepared for the Tsukuba Time Attack at the end of the year. Even though they haven't got the race donk or suspension in the car yet, it is going like a bullet. Looks awesome in the flesh - black on black - carbon doors and 10"rims all round running 285/18's. For a car that has to runs semi's it is farken quick -really impressive to watch.
Mark is quite a wheel man - coming through the inside corner on the national circuit and rounding 6 onto the straight were a sight to behold.
Good on ya guys.
Farken awesome. :)
https://www.sau.com.au/forums/topic/185315-giant-testing/
Yeh i was there also and got to watch their 32gtr, christ it is bloudy fast, and will only be faster when the new motor and suspension goes in.
mark sure knows how to steer the car well, was a great morning to watch.
https://www.sau.com.au/forums/topic/185315-giant-testing/#findComment-3353193
Yeh, car was going good till we blew the turbo. Some rubber bits blocked the oil feed and it ceased the turbo from an obvious lack of oil. That sucked cause i needed the practice on the sprint track for the state championship rd in two weeks :happy: But we found another gt35r to use on sunday thanks to Daniel - elite racing man!
https://www.sau.com.au/forums/topic/185315-giant-testing/#findComment-3353872
thanks pete!! good to catch up , your car is looking better than ever!!
and thanks michael test day was really good, it will be a pity to decals on it! hope you had a better sunday! you car sounds tough as.
will have pics soon and another test not long after, waiting for suspension and tyres. (i have been updating abit in another thread in the motorsport section " show us your racing machines"
cheers russ
https://www.sau.com.au/forums/topic/185315-giant-testing/#findComment-3356863
Arhhh nice work, I have not seen this car in ages.
Your attention to detail and setup made me foam at the mouth at first sight, Ive never seen a GTR this modified in Australia before. :D
Love to see the updated pics, and wish you the best of luck over in the land of the rising sun. :thumbsup:
https://www.sau.com.au/forums/topic/185315-giant-testing/#findComment-3357916
i can assure you the pictures dont do it justice. You need to see it in the flesh, its really really awesome.
Russ, you werent wrong about that three week wait on pwr. We had some overheating issues on sunday, so were looking at a radiator similiar to yours. Good thing i got to see your car and speak to you :dry:
https://www.sau.com.au/forums/topic/185315-giant-testing/#findComment-3358609
Russ, you werent wrong about that three week wait on pwr. We had some overheating issues on sunday, so were looking at a radiator similiar to yours. Good thing i got to see your car and speak to you :action-smiley-069:
haha i have told mark to go on a diet!! but he just looks at me! not sure why :rolleyes:
coold vids!!
michael , you'll love the radiator and temps were rock solid!!
cheers russ
https://www.sau.com.au/forums/topic/185315-giant-testing/#findComment-3359180
Would have been good to see. Have seen this thing at the wide bay sprints a couple years now. Very very quick car, seems to work well in the 'old' guise.
Was down in ipswich at the kart track saturday morning/lunch, saw quite a number of skylines going past towards qld raceway.
https://www.sau.com.au/forums/topic/185315-giant-testing/#findComment-3360025
hey guys tested out at QR today, new ohlins shocks in the car,, they were awsome!!
new vid of car after dutton rally nsw, mind you the car has changed since then and been repainted.
Marks little video!! http://www.hioctaneracing.com.au/video.php
next test is at pauls track day on the 5th at QR.
Cheers russ
https://www.sau.com.au/forums/topic/185315-giant-testing/#findComment-3379540
    • I'd be installing 2x widebands and using the NB simulation outputs to the ECU.
    • Nah, it's different across different engines and as the years went on. R32 era RB20, and hence also RB26, the TPS SWITCH is the idle command. The variable resistor is only for the TCU, as you say. On R33 era RB25 and onwards (but probably not RB26, as they still used the same basic ECU from the R32 era), the idle command is a voltage output of close to 0.45V from the variable resistor.
    • It's actually one of the worst bits of Nissan nomenclature (also compounded by wiring diagrams when the TCU is incorporated in ECU, or, ECU has a passthru to a standalone TCU).... the gripe ~ they call it the TPS, but with an A/T it's actually a combined unit ...TPS (throttle position switch) + TPS (throttle position sensor).... ..by the looks of it (and considering car is A/T) you have this unit... https://www.amayama.com/en/part/nissan/2262002u11 The connector on the flying lead coming out of the unit, is the TPS (throttle position sensor) ...only the TCU reads this. The connector on the unit body, is the TPS (throttle position switch) ...ECU reads this. It has 3 possible values -- throttle closed (idle control contact), open (both contacts open, ECU controls engine...'run' mode), and WOT (full throttle contact closed, ECU changes mapping). When the throttle is closed (idle control contact), this activates what the patent describes as the 'anti stall system' ~ this has the ECU keep the engine at idling speed, regardless of additional load/variances (alternator load mostly, along with engine temp), and drives the IACV solenoid with PWM signal to adjust the idle air admittance to do this. This is actually a specific ECCS software mode, that only gets utilized when the idle control contact is closed. When you rotate the TPS unit as shown, you're opening the idle control contact, which puts ECCS into 'run' mode (no idle control), which obviously is a non-sequitur without the engine started/running ; if the buzzing is coming from the IACV solenoid, then likely ECCS is freaking out, and trying to raise engine rpm 'any way it can'...so it's likely pulling the valve wide open....this is prolly what's going on there. The signal from the connector on the flying lead coming out of the unit (for the TCU), should be around 0.4volts with the throttle closed (idle position) ~ although this does effect low throttle shift points if set wrong, the primary purpose here is to tell TCU engine is at idle (no throttle demand), and in response lower the A/T line pressure ... this is often described as how much 'creep' you get with shifter in D at idle. The way the TPS unit is setup (physically), ensures the idle control contact closes with a high margin on the TPSensor signal wire, so you can rotate the unit on the adjustment slots, to achieve 0.4v whilst knowing the idle control contact is definitely closed. The IACV solenoid is powered by battery voltage via a fuse, and ground switched (PWM) by the ECU. When I check them, I typically remove the harness plug, feed the solenoid battery voltage and switch it to ground via a 5watt bulb test probe ; thing should click wide open, and idle rpm should increase... ...that said though, if it starts & idles with the TPS unit disconnected, and it still stalls when it gets up to operating temperature, it won't be the IACV because it's unused, which would infer something else is winking out...
    • In the context of cam 'upgrader' I mean generally people who upgrade headers/cams - not my specific change. I mean it makes sense that if I had a bigger cam, I may get more false lean readings. So if I went smaller, I'd get less false lean readings. To a point where perhaps stock.. I'd have no false lean readings, according to the ECU. But I'm way richer than stock. My bigger than normal cam in the past also was giving false rich leanings. It's rather odd and doesn't add up or pass the pub test. Realistically what I want is the narrowbands to effectively work as closed loop fuel control and keep my AFR around 14.7 on light sections of the map. Which is of course the purpose of narrowband CL fuel control. So if I can change the switch points so the NB's target 14.7 (as read by my WB) then this should be fine. Haven't actually tested to see what the changed switchpoints actually result in - car needs to be in a position it can idle for awhile to do that. I suspect it will be a troublesome 15 min drive home with lots of stalling and way too rich/lean transient nightmare bucking away for that first drive at 2am or whevener it ends up being. Hopefully it's all tune-able. Realistically it should be. This is a very mild cam.
    • Messing with narrowband switchovers is a terrible bandaid. I don't want to think about it. You are a cam "upgrader" only in concept. As you said, your new cam is actually smaller, so it's technically a downgrade. OK, likely a very small downgrade, but nevertheless. But the big thing that will be the most likely suspect is the change of the advance angle. That change could be equivalent to a substantial decrease in cam lobe duration. I haven't gone to the effort of trying to think about what your change would actually cause. But until someone (you, me (unlikely), Matt, someone else) does so and comes to a conclusion about the effect, it remains a possibility that that is the change that is causing what you're seeing.
