im putting my ceffy up for sale once again, had a mess around with the swap that was ment to go down but that went down the pooper after i put a lot of work into the car. anyway heres some specs
1989 Nissan Cefiro
5speed manual
rb20det
FMIC
aftermarket fuelpump
17" mesh style wheels decent tyres
Pioneer cd player with pioneer rear speakers and alpine front speakers
all electrics
rear cusco coilovers
Front tokico front sus, hard and firm ride
TSL tune.. makes 142rwkw (have dyno sheets)
series 2 front bar. could use a nice aftermarket bar but i dont have the money to spend on getting one
aftermarket sideskirts
aftermarket rearbar
full 3" exhaust from turbo back
[EDIT] - car has 122XXX kays on the clock..
looks and sounds tuff..
PRICE $12500ono PRICE DROP $11000 ono
any questions just shoot me a PM or call me on 0411684008
or email me on [email protected]
cheers
-Sammy
Edited by means13
  • 1 month later...
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
    • yess of course im not using 2nd hand parts from my spare engine, but the place where i live is hard to find parts for the RB20DET ,but for the RB20E is everywhere including new ones and a lot cheaper ,because for the RB20DET you have to order it overseas to get one and it cost a lot of money 3x the price to be exact. so i ask this topic because if i can use the new ones but for RB20E is it compatible or not. if not im screwed haha, not totally screwed but i have to save a lot of money first before i can begin repairing my engine, thanks for the information before.
    • Unless my sensor just died, was only a couple months old, I strongly believe it didn't. How can I test it? I never mentioned it being 20:1+?
    • Well, you wouldn't use 2nd hand bearings out of another engine anyway....so just buying the proper bearings is obviously what you're going to do. The crankshaft would be common. The conrods might be common. There is essentially nothing else you would be able to use.
