I have an adjustable fuel pressure regulator off my r33 engine for sale. not sure of any of the details of it, but the car was pushing 240rwkw with stock injectors before it was written off. I think it was supplied by wasp performance in qld.
Price is $120. And i'll throw in free delivery!
NOW $100 with free delivery!
call 0423 366 118 with questions,
Cheers,
Julian
Edited by Julzy
$110 picked up. yeah i thought it was a malpassi, but couldn't see it written anywhere, so thought it's best to be safe than sorry.
located in eltham, i can bring it home to hawthorn tomorrow though.
Edited by Julzy
