I can't do the tracert's here at work for security reasons but I can tell you that its no faster at work (using a completely different ISP) than at home.
I'll do a few tracerts tonight and let you know.
Maybe it is the Internode servers? But why is everything else quicker?
Strange one this one.
  • Replies 56
it took 20+ seconds for this reply to load lol..
C:\>tracert www.skylinesaustralia.com
Tracing route to www.skylinesaustralia.com [209.62.28.18]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms my router [10.0.0.1]
2 116 ms 69 ms 69 ms loop0.lns2.bne1.internode.on.net [150.101.180.194]
3 69 ms 69 ms 69 ms gi0-3.cor2.bne1.internode.on.net [150.101.180.115]
4 266 ms 265 ms 265 ms pos4-2.bdr1.syd6.internode.on.net [203.16.212.13]
5 266 ms 265 ms 266 ms pos4-0.bdr1.lax1.internode.on.net [203.16.213.189]
6 344 ms 435 ms 475 ms ge-7-11.car3.LosAngeles1.Level3.net [4.71.32.61]
7 301 ms 302 ms 301 ms ae-1-53.edge3.LosAngeles1.Level3.net [4.68.102.84]
8 299 ms 298 ms 299 ms savvis-level3-10ge.LosAngeles1.Level3.net [4.68.110.94]
9 * 268 ms 348 ms cr1-pos-0-3-5-0-losangeles.savvis.net [208.172.44.105]
10 299 ms 299 ms 300 ms dcr2-so-3-3-0.dallas.savvis.net [204.70.192.246]
11 329 ms 327 ms 328 ms cr2-tengige0-7-5-0.dallas.savvis.net [204.70.196.29]
12 307 ms 307 ms 308 ms 208.172.139.134
13 344 ms 344 ms 337 ms gphou2-209-85-0-105.ev1servers.net [209.85.0.105]
14 333 ms 333 ms 333 ms www.skylinesaustralia.com [209.62.28.18]
Trace complete.
C:\Documents and Settings\Jonathan>
ok, and to www.disney.com :
C:\>tracert www.disney.com
Tracing route to disney.com [199.181.132.250]
1 1 ms <1 ms <1 ms my router [10.0.0.1]
2 70 ms 70 ms 69 ms loop0.lns2.bne1.internode.on.net [150.101.180.194]
3 70 ms 69 ms 69 ms gi0-3.cor2.bne1.internode.on.net [150.101.180.115]
4 299 ms 299 ms 298 ms pos2-0.bdr1.syd6.internode.on.net [150.101.180.237]
5 266 ms 266 ms 265 ms pos4-0.bdr1.lax1.internode.on.net [203.16.213.189]
6 268 ms 268 ms 268 ms sl-st20-la-8-0-0.sprintlink.net [144.223.44.9]
7 264 ms 263 ms 264 ms sl-bb21-ana-13-0.sprintlink.net [144.232.20.66]
8 299 ms 298 ms 299 ms sl-bb23-ana-13-0.sprintlink.net [144.232.1.186]
9 277 ms 278 ms 277 ms sl-bb25-sj-9-0.sprintlink.net [144.232.20.159]
10 304 ms 304 ms 304 ms sl-bb22-sj-12-0.sprintlink.net [144.232.3.209]
11 322 ms 322 ms 322 ms sl-bb23-tac-14-0.sprintlink.net [144.232.20.9]
12 296 ms 295 ms 295 ms sl-bb22-tac-9-0.sprintlink.net [144.232.17.181]
13 300 ms 299 ms 299 ms sl-bb20-sea-0-0.sprintlink.net [144.232.9.150]
14 301 ms 299 ms 300 ms sl-gw11-sea-7-0.sprintlink.net [144.232.6.126]
15 327 ms 327 ms 325 ms sl-disne-3-0.sprintlink.net [144.232.219.254]
16 * * * Request timed out.
17 * * * Request timed out.
18 301 ms 301 ms 301 ms www.disney.com [199.181.132.250]
Trace complete.
hmmm...Where it jumps up to 250+ seems to be where it hits international.... So that response is probably ok.... except where it timesout at the end of disney.com
Only thing i could think of which could cause it on your end would maybe be the MTU settings, have you tried changing them?
ATM, we're hosting with EV1/theplanet, who are supposed to have one of the biggest backbones in the US, but it'll still be a tad delayed as the server's running at max load and because of the number of hops.
we as in SAU? Cause we're far from max load.
it's definitely not universal cause the site loads quite fast for me. using verizon at work and swiftel at home. even though my work connection is approx 10 times faster than home the load time of pages is not that much different unless they have lots of images.
hmm... wierd, we're not atm, but when I was logged in just before posting I could've sworn the load average was sitting on 3.4 or thereabouts. atho I could've misread that.
Yeah it'll get up there occasionally when a cron or rsync is running (SAU is backed up daily to my local machine) but 3.4 is ok when you consider the CPU power available. Also MySQL uses a LOT of memory atm because I was very generous in the my.cnf.
Here is mine for you all, rarely have a drama for me.
1 2 ms 2 ms 1 ms *.*.*.*
2 21 ms 22 ms 21 ms [*.*.*.*]
3 34 ms 22 ms 21 ms gi1-2.mel-pipe-bdr1.ii.net [203.215.6.22]
4 35 ms 35 ms 57 ms gi0-15-1-3.syd-ult-core1.ii.net [203.215.20.12]
5 35 ms 35 ms 85 ms 202.139.19.33
6 192 ms 192 ms 198 ms 203.208.192.201
7 192 ms 192 ms 193 ms g11-0.core01.lax04.atlas.cogentco.com [154.54.12.221]
8 192 ms 205 ms 215 ms p0-0.core01.lax01.atlas.cogentco.com [154.54.6.241]
9 244 ms 191 ms 190 ms t3-1.mpd01.lax01.atlas.cogentco.com [154.54.2.102]
10 224 ms 224 ms 224 ms t2-2.mpd01.iah01.atlas.cogentco.com [154.54.3.37]
11 224 ms 230 ms 223 ms g2-0-0.core01.iah01.atlas.cogentco.com [154.54.2.241]
12 225 ms 240 ms 224 ms v3527.na22.b015619-0.iah01.atlas.cogentco.com [66.28.65.106]
13 224 ms 224 ms 224 ms everyones-internet.demarc.cogentco.com [38.99.215.154]
14 247 ms 225 ms 227 ms gphou2-209-85-0-105.ev1servers.net [209.85.0.105]
15 241 ms 224 ms 225 ms ev1s-209-62-28-18.ev1servers.net [209.62.28.18]
Trace complete.
Hi Christian,
Thank you for your support request with Internode.
Unfortunately a traceroute will not show very good results on the Internode network due to the way our MPLS network works. As such you need to run an extended ping test to the destination to determine latency issues.
Traceroute is only for determining the routing that packets take.
There is more information about our MPLS network available at the link below, however this is only viewable on an Internode connection.
http://www.internode.on.net/faq/internode-...-traceroute.php
Below is a ping from our servers which indicates a standard ping time of about 220ms, which is standard for connections to America.
> ping skylinesaustralia.com
PING skylinesaustralia.com (209.62.28.18): 56 data bytes
64 bytes from 209.62.28.18: icmp_seq=0 ttl=51 time=219.316 ms ...
64 bytes from 209.62.28.18: icmp_seq=74 ttl=51 time=219.219 ms
64 bytes from 209.62.28.18: icmp_seq=75 ttl=51 time=219.300 ms
64 bytes from 209.62.28.18: icmp_seq=76 ttl=51 time=217.861 ms ^C
--- skylinesaustralia.com ping statistics ---
77 packets transmitted, 77 packets received, 0% packet loss round-trip min/avg/max/stddev = 217.723/218.718/219.757/0.639 ms
I can browse the site fine, and do not notice any particularly bad connections. Should there still be issues, we would need more detail regarding the Internode customers that are having an issue before we can do any more troubleshooting.
If you have any further queries, please don't hesitate to contact us in the Helpdesk on 1300 788 233.
Kind regards,
There would have been a few IPS driver errors towards the end of last week and over the weekend, but there shouldnt have been any this week. If there have been, can you tell me at approx what times?
As for the slowness, I am going to look into our DNS, but apart from that, I dont think there is anything I can do.
    • Hey, guys, I’m hoping I can find answer here. I have already done some searching and asking around but still nothing.    I fitted an IC7 dash in my R32 GTR, and I got everything displaying on the dash except my high beams. I get input voltage and the high beams displaying in the dash when I pull the lever, but not when I fully engage the high beams. I spliced into the Red/Blue Beam+ wire in the black center connector from the cluster, but there is also a black Beam wire I think I need to use as well. The high beams still work. It’s just a matter of getting it to display on the dash.    Has anyone fully wired in their IC7 properly ? I would appreciate any guidance on this.    IMG_8835.mov
    • I buy my wheel cleaner in 4 litre bottles now. Euro brakes are brutal
    • Sounds like it may all just be some baseless outrage stoked by the carexplore guy? As in the linked social media outrage on facebook just goes back to carexplore as a source again. Further shown by the council response that nothing actually has changed: "The Private Land Use Permit has been part of the Casey Community Local Law for a number of years. It's important to clarify that this permit is not new, and no changes have been made to the permit or the Local Law in relation to the permit." The full council response in Prank's link sounds reasonable to me. Saying that as someone who neither lives there nor has a front yard to call their own
    • Clutch hydraulics are also all good, looks like a brand new slave cylinder and everything bled up well. No idea what the actual clutch is, and I don't intend to pull the box off on the floor to find out, so unless we have trouble on the dyno or at shakedown that will remain a mystery for the new owner
    • Front brakes are G4 8 pot calipers over 330mm discs with braided lines. Everything looks good, pretty sure these are off my old 350. Pads are brand new and judging from gold colour are Winmax which is what I also run on my race car, Neil and I both sourced brake stuff from Matty at Racebrakes Sydney who really knows his stuff Everything has bled up nicely with all new Motul RBF600 fluid, there were 2 loose hard line connections and the calipers were new on the car so I ended up doing it 3 times but it is perfect now
