Hey guys,
Went about installing my Greddy turbo timer into my car which I bought equipped with a M80 Mongoose alarm.
Turbo timer shuts off when the ignition is turned off, which is understandable as the M80 has the turbo timer function set to off as default.
I went about turning the ignition on/off the required number of times with the drivers door open, to access the alarms contols, and after I did the right amount of on/offs, nothing happened (indicators ment to flash etc).
I tried to do the same again and turn the beeps on/off without any avail.
Thinking of taking to a local dealer who has done some other audio work on the car. Just thought I'd see if anyone else had a similar issue.
Every other function works with the car.
https://www.sau.com.au/forums/topic/185353-mongoose-m80/
there is a 5 sec time window to get into program mode. turn EVERYTHING in the car OFF before you start programming it. then start the routine. turn the key quickly when doing it and at the end you will get chirps & flashes, in the last one press button one.
if the timer is connected UNPLUG IT.
this will allow the alarm to arm with the timer you have in the car - IT DOES NOT TAKE THE PLACE OF IT! :(
once you get it set up plug the timer back in start the car wait a few minutes then turn the key off, timer counts down - press and hold button 1. you will get a chirp . opening the car with the key will set the alarm off and shut the car down.
if you get that result it works :D
https://www.sau.com.au/forums/topic/185353-mongoose-m80/#findComment-3355151
  • 1 year later...
Hey guys, just wondering - my car came with a mongoose alarm, but i'm not sure what model it is. It's got a 2 button remote. I want to find out if i can get the instruction manual for it, coz i want to install a turbo timer... any ideas how i can identify it?
https://www.sau.com.au/forums/topic/185353-mongoose-m80/#findComment-4378067
The problem is that when you start the programming sequence you basically have a window of only 15 seconds to turn the ignition on and off the number of times for the feature, and for features down the list like the turbo timer function which is number 13 means you have to turn the ignition on and off 13 times in 15 secs of opening the door. So it has to be quick. If your turbo timer is on then it obviously holds the ignition on, preventing the programming working properly.
This is especially so with the Greddy Timers as even when they are set to the off position they actually stay on for .5 of a second after the ignition is switched off, hence this adds .5 of a second to each time you turn the ignition on and off. You dont necessarily have to disconnect the timer but just do the programming fast :) or to make it easier you can disconnect the timer till its programmed correct :mage:
Regards,
Daniel Gardener
Platinum Car Security
Hey guys,
https://www.sau.com.au/forums/topic/185353-mongoose-m80/#findComment-4392123
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
