Hey Guys,
Great forum and I am sad to say that my first post is a question of which I rekon I already know the answer but am after some direction from any RB20det owners.
Below is a video of my beast idling and you can hear a dead set knock of death.
The car is a datsun 260z and I am looking at getting about 300-320rwhp reliably.
Mods so far
IC
microtech ecu
t3/t4 turbo
soon. supra injectors
fuel reg
larger fuel pump (if needed)
Question: Should I just pull the sump off and replace the busted bearing (if thats all it is) or would the RB20det need new pistons, rings and a clean up to acheive 300-320rwhp reliably?
I have no idea on how many K's the engine has done. Conversion was done in 2005 and hardly any miles put in it since then.
Thanks for your time.
shit, the video link -
https://www.sau.com.au/forums/topic/185375-rb20det-knock-diagnosis-video/
yes that does sound like bearings, i personally would rebuild the thing while you are at it, the motor might last a few years with that power or could last a few days, all depends on the condition of the rings and ring lands.
you COULD just replace the bearings, but keep in mind that they dont start knocking for no reason... something have starved them of oil so if you go down that path its most likely going to do it again. You oil pump could be on the way out or you could have other issues.
Personally, i would just get another good con bottom end 2nd hand and wack it in and thrash it
Wack it in and thrash it! I love it!
Any tips on where to look for rb20 bottom ends? Apart from here, ebay and other forums.
I see some rb25's complete for like $1500 - maybe I should search on exchangability of parts and just step upto one of them.
Lifters are the higher pitch ticking which goes away once the oil pressure goes up. Well mine do.
Sent a dozen e-mails to some wreckers on quotes. rb20's seem to be cheap!
Pistons etc seem overly expensive for what an entire motor is worth. any OEM suppliers out there?
    • Surely the merged entity will be called "Honda" given the relative company values. I've got to be honest, I don't understand how merging 2 companies that missed EVs (despite Nissan making the first mass produced one) will solve their problems
    • If you haven't bought the ECU yet, I would strongly consider buying a modern ECU. Yes it is very easy to setup and tune, however it is lacking many of the features of a modern ECU. The pro plug in is something like 10 or 12 years old now? Can't remember exactly but it is very dated now. In that time the Elite was released and now we have the Nexus platform.  I would strongly consider not buying the ECU that is 3 generations old now (especially as it isn't a cheap ECU!).
    • Im happy for it as long as it means reanult gets the boot
    • Sorry I should have been more clear with the previous post.  The block is a sanding block - picture something like this https://motorguard.com/product/motor-guard-bgr161-bgr16-1-rigid-psa-sanding-block-2-5-8-x-16/ The guide coat is the paint It's two separate things I was talking about, there is no "block guide coat".
    • Maybe more accurately, you aren't just dulling the existing paint, you are giving the new paint something to 'grab on to'. By sanding the existing paint, you're creating a bunch of pores for the new paint to hook on to.  You can lay new paint over existing paint without sanding it, might last a year or two then sad times. The paint will peal/flake off in huge chunks. By sanding it, the new paint is able to hang onto it and won't flake off.  Depends on the primer you are using. When you buy your paint, as the paint supplier what grit of sand paper to use before you lay down the primer.  Use whatever you like as a guide coat. Pick a colour that really stands out in contrast to the paint. So say your sanding/painting a currently white car, using a black guide coat would work well. You very lightly lay the black guide coat down, then as you sand the car with the large block, all the high spots and low spots will stand out as the black paint is sanded off (or isn't sanded off).  When you buy your paint, hit up your supplier for recommendations for what paint to use for a guide coat if you're unsure what would work well with your setup.
