Whats the proper way to tighten these. I see it has the lock nuts on the end and it looks like you loosen these remoce the bolt from the mount screw in the threaded lug and put the bolt back through. This doesnt seem right though as it would be a strain getting the bolt back through. I would have thought you fit it all tighen it up and do up the lock nuts.
Thanks for any help.
https://www.sau.com.au/forums/topic/1854-cusco-brace-adjustment/
Yeah thanks I figured that much out. But if you know the Cusco set up there is no adjustment to pull the bar tight and then lock it. As far as I can see you fit it remove the bolt, screw the adjustment in, guesstimate how tight it is and fit the bolt again. However it will be only as tight as much as you can hold the brace by hand and fit the bolt.
Anyway I have it sorted now.
Thanks all!!
