ok so i recently pu some 550cc injectors into my rb20 and now its decided to run on 5 cylinders
i understand when changeing injector into a car thats not tunes for them the car will run rough is this 2 rough
now i dont want to got o a tuner and them tell me that the injectors r f**ked and have to pay for a nothing result and still be up for new injectors the car did run on 6 cylinders for a short period of time after i turned the fuel pressure down but now it's back to 5 when i purchased them i was told they has just been highflowed and unused since with new o rings fitter now this it did have new o rings so am i to pesime the rest is true i need help
https://www.sau.com.au/forums/topic/185406-bigger-injors/
have you checked that all the plugs are making contact? Start with the basics and while the engine is running pull a plug off the injectors (thats how you spell it btw) one at a time until you find the one thats not working.
It could be a sticking injector... replace with another one or get it cleaned and benchtested
https://www.sau.com.au/forums/topic/185406-bigger-injors/#findComment-3354955
i would be getting the injectors flow testing not just to make sure the highflow was done right otherwise you might have one that is 555cc and another that is 530cc and this will make a difference in engine life. also it will tell you if one is stuffed.
https://www.sau.com.au/forums/topic/185406-bigger-injors/#findComment-3354958
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
