Background:
Bringing a Stagea in via Sydney drive on/Drive off stylez through J-Spec :mellow:
Customs Broker
What are the pros/cons of using a Customs Broker? How much do they charge? Recommendations?
Is it easier to not use a Customs Broker?
Quarantine:
Do I physically have to go to the docks to 'sterilise' the car myself or not? Powerplay Imports gave me the impression I have to clean the car myself, doesn't bother me i'm used to hard work but i'm just clarifying before rocking up there with cleaning aids on to find out it's been done.
https://www.sau.com.au/forums/topic/185449-customs-broker-customs-questions/
Background:
Bringing a Stagea in via Sydney drive on/Drive off stylez through J-Spec :)
Customs Broker
Quarantine:
You have to have the car cleared through customs by a licenced agent, most charge around $100 to $250 for their service depending on exactly what they do. You can choose a cheaper agent who only does the actual clearance and do a lot of the running around yourself if you want but it would only save you $50 to $100 and would be the most painful 2 days of your life if you haven't done it before - even after importing as many cars as I have personally I would still use a customs agent who offers the full service.
Usually we arrange the clearance for all of our clients through the most appropriate agent at the time, however you can arrange it yourself but please make sure you let us know so the clearance isn't lodged twice by accident.
Quarantine (AQIS) inspection is done to ensure there are no plant or animal materials on the car, usually they look for things that could start growing like seeds, berries or insects. About half the cars inspected will be ordered for steam cleaning and/or vacuuming, in most cases it's just as a precaution and there is no way to tell which cars will be effected - we have had spotless clean cars sent for steam cleaning and other times cars with heaps of dirty that sailed right through. If the car is ordered for cleaning then it must also be done by an authorised Quarantine approved facility so you can't do it yourself.
Let me know if you have any other questions at all. :D
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
