SAU/SA Club
132 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 165
Sounds great - Definately in, although I am away with work alot I'll be there for everything I can be! We could also incorporate an SAUSA shirt/sticker into the membership price? I'd be willing to pay $50 - $60 bucks for the year if this was the case - any others keen?
Here here! A standard polo or T would work! and possibly a common sticker! likewise with the payment $50-$60 would be no skin off my nose!
Obviously Cubes i'd put my hand up to help as much as i can.......
Guys and gals, lets not talk dollars, or what free gift you should get (how about some steak knifes? :wave:).
It's way too early in the game for that, I'm certain what ever price that's arrived at will be the minimum necessary amount, for the moment lets see if we can get the wheels rolling in earnest first.
Cubes
If you get it all off the ground I would be interested too.
Like evil34 I was also on the committee of SVD, and I still have a lot of the paperwork from the club, there may be some information in there they could be helpful to you. If you think it could help you just send me a PM
Best advice would be to run about 6 months of events and meetings before you get too serious just make sure that the interest is there. You don’t want to have meetings if only the committee is turning up.
Simon
whats the likely hood we can get the basics sorted like CAMS affiliation and basically thats it and get the core of SAU in and then sort out sponsorship and stuff like that for our 2nd year of running
ive already spoken with a trader and he is happy to sponsor SAU but is doesn't suit all people but thats going to be the case for different sponsors depending on where there located, and this sponsor ship was for something else but i know he means all things like this also
    • How's your first born doing? 😛 As for now what? Time to forget about it for 12 to 18 months while your go down a totally unrelated rabbit hole... 😛
    • Fuse taps are perfectly fine to use, especially when you're adding stuff for your own car, and so long as you're being smart about it. IE, don't throw a 30amp circuit, onto a circuit that is only a small circuit. It's best to add a small circuit, to one that is already quite large. Oh, and make sure you're not going to blow the fuses that are further upstream too! I dislike their use in other applications, such as alarms, telematics/tracking devices etc, as it's far too easy for someone to unplug them and render a system useless. Those sorts of devices I go for wiring in quite secretively.
    • Fob is all cleaned up and it’s working well!! The amount of Vegemite looking sh*t that was in there is mind blowing
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
    • Finally for now, a bit more work on the transmission temp gauge. I was wondering how Raceworks do a gauge for $100 that autometer want $500 for. No idea about the accuracy of course, but they have cut a few corners that made things hard.  First one I mentioned above, the sender is physically difficult to fit and doesn't work with their own adapters (the extra fittings I used to get the sender into a hose cost more than the whole gauge, lucky I had stuff in the shed) Second, the temp sender wires are way too short. They are shown as 2.7m on the box and I know my routing was long from navigator headlight to driver's firewall back to centre console, but I had to lengthen them by about 2m total - 2 joins in each wire. Also, same with the supplied power loom, they needed about an extra 1m to get the fuse box where I sourced power. Another join in each wire since one end wasn't supplied terminated. I know they could argue that the wires might be long enough depending on situation, but when you consider parts and particularly labour, it would be a very expensive cheap gauge if you can't do the work yourself. And, only a small issue....but it would have been nice if they remembered to tap a tread onto *both* spacers they supplied for the bracket....I haven't had to use the M4 tap often!
