Just after some help on engine/gearbox mounts in my R32 GTS4, I find when under power the engine/ gearbox moves alot, which makes it hard to select gears when you change.
Are any other people having or had trouble like this?
What engine/gearbox mounts are other people using in their high powered cars, and does it fix the problem?
Edited by sky30
Just after some help on engine/gearbox mounts In my R32 GTS4, I find when under power the engine/ gearbox moves alot, which makes it hard to select gears when you change.
I changed to NISMO mounts all around.
What you have to remember is the stock ones in there (assuming they haven't been changed before) are now 15+ years old and have seen a fair bit of action in that time.
Buy new ones, put them in and notice the difference, you wont be disappointed :P
I guess a lot of people would be using Nismo.
Maybe you could get an engine damper. Even if it doesnt work well, its bling for the bay :ninja:
Damper's dont do dick other than take up space under the bonnet.
Get the new mounts and your problem will be solved :P
I went stock everyhing with my 370rwkw. Seemed ok to me even under full song @ the drags when i was full power.
Pulled it all out as part of the 26 conversion and all was well. No wear at all after some harsh km's.
Given though i had a stock crossmember that was modified to accomodate the RB25 box (as opposed to RB20 box which mounts differently).
So possibly the change that incorporated a better fit possibly?
I also had brand new diff mounts/cradle bushes aswell as i did have issues previously with things moving around a little.
Andrew,
Are you sure you haven't busted an engine mount?
When I dropped the RB30DET in I replaced mine with new ones from Nissan. 50,000km's later I busted the passenger side engine mount. :P
I believe it was most likely related to axle tramp. Subframe bushes sorted that.
No doubt with the GTS4 + Rb30 and near 400rwkw you will need something better. I guess you could try nismo failing that I don't know.
See if its possible to have some urethane's made up if not umm solids :S
had a poly g'box mount noticeably louder and more vibration in cabin compared to the nismo engine and box mounts I later changed to
g'box mount is easy to change with jack and stands, the engine mounts were a pain and that was with a hoist
we made up some solid ally engine mounts and we welded up the std gearbox mount. At 370rwkws the std engine mounts seemed fine, one race meeting at 400rwkws and we broke the p.s mount. So i figured we would need something remarkably stronger for over 450rwkws.
Best thing i noticed about the gearbox mount being solid was how easy it was to change gears. With the dog box, i found during one race i would crunch atleast 1 gearchange, after the mount change i didnt crunch any.
haha solid mounts in a race car you cant even hear the extra noise from vibrations lol.
Edited by r33_racer
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
