just a quick question. If you take the power fc out (r33 gtst) and put in the standard computer will anything happen to the map on the power fc. Ie, when you put the power fc in again, will everything be as they were before it was taken out?
cheers
Anton
Edited by moonus
https://www.sau.com.au/forums/topic/185494-power-fc/
how long can it stay off power to hold the tune?
Hey,
I would say that it wouldn't drop the tune at all unless manually reset to factory default or something. It obviously stores it in some type of ROM that doesn't require power to retain its memory, otherwise you would loose your tune every time your battery went flat or you disconnected it for some reason.
Cheers!
Gagz
https://www.sau.com.au/forums/topic/185494-power-fc/#findComment-3356960
Guest
