Drag Time 2007 - Sunday 28th October 2007
It has a new name but it's the same day as the last two I have organised cool.gif
It's a case of first in best dressed so those that have their place paid for first are guaranteed a spot; the numbers are limited yet again so get in quick. You make the list ONCE YOU HAVE PAID, not before.
SPONSORS OF THIS EVENT ARE:
* McKern and Associates
* Redcliffe Dyno & Performance
* Boostcruising
________________________________________________________________________________
The important information is as follows:
Date: Sunday 28th October 2007
Time: 9:00am to 3:00pm (competitor gate admission between 8:00am and 10:00am ONLY)
Cost: $90.00 per entrant (gets 1 racer and 1 passenger in the gate)
Positions Available: 90
Spectator Entry: $10.00 per person
To sign up please post in the one thread I am managing * click here *
Thanks all
Just so you know there isn't a cent left over from this day. My main sponsor actually picks up the left over costs which is usually the trophies.
Also have a look at the latest Fast Fours and you'll find a 6 page write up on the last day I organised :thumbsup::D:(:yes:
And thanks for posting it elsewhere :)
Its all good Ang... :thumbsup:
Just so you know the in's and outs Dale, I enquired about a day for SAU early last year...
The hire of willowbank generally is in excess of $7500 for the day (back in 2006 when I priced it)
I think there were some serious conditions at this price also, like it was a 10am til 5pm run time and no entry was allowed to be charged at the gate, no food stalls would open, traction compond was $1000 extra, 7 support staff which means in a accident it would take a while to clean, so on and so forth...
So the cost for one of these days is fairlly heavy to begin with, hence the $90 per car entry and believe Angela every cent gets chewed up...
But think of it this way, a TnT night you pay $38 and would be lucky to get say 4-5 runs in before they shut the gates...
This is cause over 200 cars turn up every time and a tnt has a shorter run time, so imaging what you could do with half the cars and an extra couple of hours up your sleave... :happy:
At this event there is a limited number of cars, so your gonna get in at least 15 runs maby more...
Id be there myself if I didnt have other things on that day...
Thanks so much :P It is hell dear and my stress levels are up there organising it :P
Side note someone got in 32 runs last time and actually broke the Willowbank record for the most runs in one session :D
wow thats crazy. quite expensive to say the least. I appreicate you both explaining that to me , excuse my ignorance :rant:
All good :rant:
  • 3 weeks later...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
