Skit 31.
What cams are you running? Duration/Lift? :(
Got any audio/vids of how it lopes over? Very keen to have a listen.
I dont as of yet, but will do soon, ill post a clip soon, got a mandrel 3" exhaust, massive long hotdog and magnaflow mandrel centre-offset muffler, being fed from some Jasma Extractors (damn they are nice! 6-----2-1 emptying in 3") - and yes it needed the 3", lost nothing down low, gained sooo much up top, deep and angry note
The Cams arent that impressive, 255deg & 8.3mm, with adj cam gears, but its still lumps happily (@ ~ 700rpm) making peak power at about 6500rpm now, give me a couple weeks and ill have a film clip of it on the dyno, oh i cant wait for that...
Edited by SKiT_R31
  • Replies 66
cheers SKiT_R31!!!!!!!!!!!!!thats made it a little easier! lol............i already take my car to 1000-1500 rpm for take off.........so i should be fine when i get the flywheel!!
:whistling:
  • 2 months later...
hey guys, been reading this thread and was planning to get a lightened flywheel myself but since going through how it will reduce torque and be crap uphill i have some doubts lol.
I have come across this billet steel flywheel on ebay
http://cgi.ebay.com.au/Billet-Steel-Light-...bayphotohosting
i have a NA r33s2 gts4, i will be changing to an exedy sports organic clutch coupled with a lightended flywheel. I just need some recommendations on what weight flywheel would be ideal i,e wont die too much uphill and launches/take off, would a 5-5.5kg flywheel such as that one in link above be ok?, or am i better off gettin the more expensive 6.6kg? exedy flywheels?
thanks for any help! :rofl:
Edited by OoskylineoO
Since my last post on this thread I have had my toda light weight flywheel with a organic clutch and heavy duty pressure plate installed. Gota say I'm impressed with the results the car feels so much more responsive, and is much faster over taking and coming out of the corners, it revs up much quicker.
I was concerned about how the car would react on the hills but I was surprised there's very little difference as long as you keep constant pressure on the throttle, if you reduce the pressure on the throttle the car will slow down much quicker than it use to going up hills, but a quick down shift and stand on the go pedal and the car moves along quite nicely. I haven't tested it on the race track yet, but will next month.
i have a lightweight flywheel and let me tell you there is no loss in torque. it revs up quicker and is generally more fun to drive. the only disadvantage is slightly higher revs required to takeoff (talking like 50rpm more) - really only noticeable when taking off on a hill. hope this helps
hey everyone the lightened flywheel and clutch will be going in on thursday next week - a long with some new front shocks too.....
soooo im going with the chrome moly lightened flywheel (approx 5.5 kg) with a heavy duty ceramic cushioned button clutch - only reason im going with this one is i will need somethng that is gonna be strong on the track when i use the nitrous oxide system. and speaking to alot of people they all said to go with the ceramic cushioned clutch.
nice work cara, eagerly awaiting results.
is your car still a daily driver? i don't know why you are so adamant on the button clutch. if you do more street driving than track, then i guarantee you will end up driving like/slipping like its a regular h/d clutch. of course the clutch is stronger, but your damaging the other components by increasing unnecessary wear and tear.
they're really more of an on/off type thing, but hey if your not paying for it then sweet.
p.s. - upgrade your pressure plate!
I had a button clutch in my car for the past 5 years, great for the track but not the best for a daily driver they take a lot of getting use to, and in bumper to bumper traffic jams they can lead to some pretty embarising bunny hops and stalling issues, and they chew the crap out of your flywheel and pressure plate too, I've got pics if you would like to see.
I've just recently changed to an organic and H/D pressure plate and toda flywheel it's so much more drivable on the street, guess I'll find out what it's like on the track in the weekend lol
wont i get a new pressure plate with the clutch kit?
yes she still is the daily.
apparantly the cushioned heavy duty clutch has a lot more give than what the normal heavy duty ceramic button clutch has
Between the solid button and cushioned I've noticed next to no difference.
I origionally had the Xtreme 9puk cushioned ceramic which was grabby; compared to the Exedy 4puk GTR solid ceramic I'm not running I find the Exedy clutch is more progressive and smoother but grabs a hell of a lot harder when you want it too. Personally I prefer the Exedy Solid. Much nicer feeling clutch.
In short the clutch can be ridden very easily BUT riding a ceramic clutch will kill it VERY quickly so don't ride them; slight rev increase then simply pop it out which often than not causes a slight chirp of the tyres.
Driving the 9puk as above I managed 70,000km's out of it where as I've known some who only get 20-40,000km's driving the clutch as you would an organic.
I've had organics last 100,000km's.
hey guys i just spoke to a guy at adelaide clutch services
the clutch kit comes with an upgraded pressure plate.
the lightened flywheels are made to go with the cermaic clutches
the pedal pressure is about standard, therefore it wont add to much pressure to the hydraulic system etc.
if i was to go with the organic clutch, it probably wont last very long with the nos kit on the track.
yes the clutch will be more aggressive on take off but i just need to get a little more revs :)
i told him that it was a n/a r34 with nos kit lol
My button clutch feels lighter then my mates old stocker clutch.
Yet, I still tore the bracket off the top of the fire wall...
Be aware, the button does more then just put strain on your drive line.
It'll chew tyres, it makes parking a bitch, bumper to bumper traffic WILL send you insane, and basically no one else will be able to drive it.
It also makes quick take offs at the lights ALOT harder without frying up a set of tyres.
I have a button in my R33 with a 4.8KG flywheel... The button clutch is coming out hopefully when new motor goes in, and I'll be headed for an organic.
    • I should try the experiment you're talking about, the throttle switch is still there carried over from the R32 and it's still all wired up but after I did the whole intake manifold refurb and had to recalibrate the TPS I managed to somehow get the idle switch reporting activation at 0.22V, then when I adjusted it to 0.45V for idle it decided the engine was permanently no longer idling which caused some very weird behavior, closed loop idle was disabled so it would basically be at the whims of the cold start valve and whatever the base timing table was at. Then just unplugging/replugging the TPS with the ECU live caused it to relearn the idle TPS position and decide 0.45V was idle. Presumably there's nothing in the TPS that allows for the throttle switch to "recalibrate" like that, not easily at least.
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
