AAArrrrrggghhh, I have lost my spare key (black hole somewhere) and I have been told that although Nissan can get a replacement key ($$$) I need to get it cut and coded somewhere else. Has this happened to anyone? and does anyone know of a place where I can get the key coded?
nissan should be able to do it. or any workshop with a decent scanner like the new modus snap on scanner or a launch. you dont have to replace the body control module like with the new falcons an magnas do ya?
All you need is the key code, it is on a little metal disc / plate with 5 digits.. you give that to the key man and he cuts it to that shape.. then you go to Nissan for a coding.. Coding is 55 Dollars at northside nissan
Thanks, The guy i talked to at magic nissan said that they couldn't do it, but it might just be that they haven't had to yet. I'll try northside. No key number on original, but it's good they can do it off the VIN.
    • We will review wtf is going on, but if you made any donations let me know and i will follow it up with the admins
    • See, that button sounds like perfection Duncan! My eyes really don't like light shining at them from a dash when I'm driving. Being part red colourblind, I've found for most cars that I can change colours on, I set everything to red, so my eyes see the elast amount of colour! I miss normal gauges in cars
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 🙂  I know what it looks like
    • Oh, there's also the gearbox crossmember which will probably be different between the small box and the big box, and the wiring loom will probably need to be modified, because the plugs for the switches etc, will probably be different. And I think the speedo on the small box R34s is from somwhere stupid, like the diff, possibly, so you'd need to work out what needs to be done about that (assuming it is different). I think the thing you need to realise is that the front end of that yoke is a large hollow tube with splines on the inside that mates with the splines on the box's output shaft. It is a dedicated thing - not available "aftermarket". They were made to suit that box, by the car's OEM.
