Hi All, i am very interested in these M35.
Regarding the 4X4 system does any one no much about the distribution of power?
Is it like the older GTR systems full rear then spread to front when rear slips?
Are there aftermarket bias controllers available?
Regarding parts and so on what kind of costs are there? EG Auto failure Big Stuff and little stuff brake pads what fits.
The Big Question: Insurance? are there any 26 year olds on sau that have one of these fully insured? What does it roughly cost ?
Any futher info would be greatly appreciated
Pikie
The 4x4 system is rear biased but upon slips allocates upto 45% (from memory) to the front. On the ARX it has a limited slip rear diff as standard. The ARX also has 2 syncro modes for starting on gravel or snow. This allocates some power to the front up to certain speed then it goes back to rear bias and power to front on slippage.
Have a look at the link, http://www.nissan.co.jp/STAGEA/M35/0110/, there are demonstrations of various functions including the 4WD function and the modes.
I insured through Just Car as Shannon's would not insure me without a garage in NSW.
Andy
https://www.sau.com.au/forums/topic/185569-m35-info/page/2/#findComment-3536578
Hello,
I recently got my car insured by Famous Insurance ( Ex Vigil), previously they did not do M35 Stagea's, but after some discussions with their underwriters they now do them. I got a good quote for my Stagea AXIS. Under $1200 for a rating 1, over 30 on the Northern Beaches of Sydney.
If you need more details PM me.
Jules
https://www.sau.com.au/forums/topic/185569-m35-info/page/2/#findComment-3552962
Hello, Just some pics I saw on the net about the Blitz FMIC for the M35 Stagea.
For those interested. But would it provide any decent benefit....thoughts anyone.....
Edited by Paramour
https://www.sau.com.au/forums/topic/185569-m35-info/page/2/#findComment-3580461
Ahhhh....looks like a good setup for the intercooler.
P.S. Like what they have done with the mesh over the inspection port on the cold air box....must get the mesh and do that myself.....saves buying a POD filter and produce's the same result.
P.S.S Also got a quote on doing the turbo up yesterday....not cheap...$1,200 for the highflow and new impeller.....good for 13PSI everyday though....must do!!!....must get more HP.....lol
https://www.sau.com.au/forums/topic/185569-m35-info/page/2/#findComment-3582049
Have you seen the airbox of a V35? They have a piece fitted to the front of the airbox that works to have it open like that and only get cold air!
https://www.sau.com.au/forums/topic/185569-m35-info/page/2/#findComment-3582119
sounds a lot cheaper than mine even with exchange rate and 12.5% gst factored in but I prob paid the mechanic's markup as well
I notice it feels stronger but there's more lag
can't tell you about hp as I haven't dyno'd it yet
https://www.sau.com.au/forums/topic/185569-m35-info/page/2/#findComment-3582180
You got pic's of it?
Anyway thought I might post this here as well....its a pic in English of the DVD/TV/SatNav unit.....now we just have to sorce the button's.
Have a look at the intake on the far right of the picture.
Let me know if you can source the buttons? Do you have any contacts in the US?
https://www.sau.com.au/forums/topic/185569-m35-info/page/2/#findComment-3582499
What we really need is the English version of the software so we can read the screens!
https://www.sau.com.au/forums/topic/185569-m35-info/page/2/#findComment-3582503
Thanks for all the information, I am very interested in getting one of these M35's.
Quick question tho: I am trying to work out how what model gets the 3 gauges in the center console unit? from looking at the pictures I think they are turbo pressure, oil temp and maybe volts?? Obviously i would like to get a car with this as an option.
Or, does the TV screen display any engine management at all?
Cheers.
Also, has any one registed one of these in south australia? will I have any problems if I buy from interstate and register here?
https://www.sau.com.au/forums/topic/185569-m35-info/page/2/#findComment-3593242
I am pretty sure that it's the 2002 - 2003 Nissan Stagea 25T FOUR-V 4WD turbo your looking for. As for the TV screen....next to no info is on this....infact it's pretty useless until you convert it for TV/SatNav/DVD. The TV does display however your direction and fuel/travel info....plus some other shit of which I have no idea....need a translater...lol.
As for rego, I'm no expert but once it's complied you should be able to register it in any state(check with you dealer/compliance first).
https://www.sau.com.au/forums/topic/185569-m35-info/page/2/#findComment-3593271
having just got back from a trip up north I will say that this 250T RS four is an awesome touring wagon and will not disappoint
has tonnes of torque right where you need it and the awd comes into its own on those steep metalled surfaces where traction becomes an issue and in the wet, the tail-end of cyclone funa having crossed my path
I would like the ar-x if only for the fact that I like to venture over rougher ground where clearance is necessary
https://www.sau.com.au/forums/topic/185569-m35-info/page/2/#findComment-3595694
    • Does it make a difference in your turbo having a shorter life if you have a cat converter as it causes that back pressure versus less/no back pressure with a decat? (Not sure if this is accurate) Also slightly different question if you went from a oem cat to a decat or vice versa will it require a tune? I heard if you change the dump pipe onwards it requires a tune?
    • No. Have only gotten as far as contemplating the task of having to put in the required fairly heavy wiring and fusing to run it (along with the big alternator), and preferring not to. But otherwise, it would be nice to have a little extra freedom as to exactly where the compressor is located and free up some space around the exhaust side of the engine.
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
    • Bit off topic maybe but has anyone had a crack at one of those aftermarket electric compressors ? Bit of a search came up with one put out by Speedy Air Spares. Looks interesting and looks as if you'd have to run a big arse alternator. Found this out after the fact as my air con compressor packed it in and soon after my alternator ! !
    • Yes. Needs new ports. Usually just achieved by screwing an adapter onto them. Be aware that any AC compressor that hasn't been used in a long time will very likely have dried out seals and will not hold gas. Oh, and obviously you will require a new receiver-dryer also.
