i just tried slidewize and no luck. i called nissan and they tell me that nothing shares the same part number for the m35 air box. but i'll keep trying.
Silly question and you have probably already done it but....have u tried going into the V35 skyline forum/parts for sale and seeing if someone who has put a POD on that want's to sell there airbox?
Edited by Jetwreck
https://www.sau.com.au/forums/topic/185569-m35-info/page/7/#findComment-3691087
I looked at the one in my stagea and the one in a V35 Skyline and man they look identical, I could be wrong....but they looked like they would clip right in each other, I was looking as the V35 has a small intake to allow more cool air.......just a thought.....
Let me know if you find our for sure as I would be keen to know.......
https://www.sau.com.au/forums/topic/185569-m35-info/page/7/#findComment-3691439
You are right. the V35 & M35 have the same part number. They are, Back of airbox 16526, front of airbox 16528, + filter required.
Cheers
Andy
https://www.sau.com.au/forums/topic/185569-m35-info/page/7/#findComment-3691535
Cheers
Andy
Gotta love that FAST aye!!!...any news on the bit we are looking for yet Andy?
https://www.sau.com.au/forums/topic/185569-m35-info/page/7/#findComment-3691681
I haven't had a chance to contact Nissan and probably won't tomorrow either. Any chance you could give them a call?
It is called a Powerbox (part No 16500X) needs the same stud the secures the current cover to hold it into place. If you can do this, can you also check the price of the stud (16528F)
Cheers
Andy
https://www.sau.com.au/forums/topic/185569-m35-info/page/7/#findComment-3691773
yeah i got that on my screen to. can you give me some more info on how to reset it. i tried to do it today but was unsucsessful.
i also found a v35 air box that is for sale. :yes: does anyone know if it will fit for certain
Yes it will, same part number see above.
Cheers
Andy
https://www.sau.com.au/forums/topic/185569-m35-info/page/7/#findComment-3694070
Cheers
Andy
Sorry missed this till now....will do tomorrow first up.
https://www.sau.com.au/forums/topic/185569-m35-info/page/7/#findComment-3694209
i also found a v35 air box that is for sale. :cool: does anyone know if it will fit for certain
The best I can do for you is below....other than that just keep pressing button's....lol
https://www.sau.com.au/forums/topic/185569-m35-info/page/7/#findComment-3694259
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
