and where would one get this special blade and perhaps a part number
thanks
I normally renew the front pair, and cut down one of the old ones to use on the back; as Aaron says, pre bend it to suit the curve.
Plastic backed blades are shit; not flexible enough.
I only use the rubber ones with two stainless strips in them; over the counter at Repco is the only place I can find them anymore...
thanks
as Dale said. no special part, just cut it down to size.
i use the teflon stuff. had it for about a year now and it still works as if they were brand new!
Is the rear qtr panel on the M35 replacable? Or is it part of the whole body?
My wife cleaned out a brick fence while backing my car out...
Just wondering of the driver side rear qtr panel is replaceable.
Cheers...
EDIT: I think this is it?
http://translate.googleusercontent.com/translate_c?hl=en&rurl=translate.google.com&sl=ru&tl=en&u=http://www.megazip.ru/ru/auto/nissan/view/41/51/1900/58826&usg=ALkJrhiw7tWPbTVTQsKiBYj60Nr8xP4_Rw
Edited by ironpaw
Cheers...
fuuuuccck man.. even your light was gone.
i think they angle grind a section out if it cant be bog fixed. and weld a replacement and fix n paint.
Depending in the scale of the damage. You might be up for a new rear quarter.
Not a bolt on part; extends up to the roof at the C pillar, and all the way forward to the rear door...
Taken a pic?
yup, cut the spot welds and replace the panel.
if you were in sydney i can supply a 2nd hand rear quarter if you need it. but that will be gone pretty soon
As in someone is buying it?
I'm gonna just go thru insurance anyway...but want to see if they can just pay me the $$$ instead of having them repair it seeing its just panel damage. I know RACV allows this...
then I'll just hit up some cheap 2nd hand parts (already have tail light landed for $150) and get a decent import repairer to fit and fix it all.
Edited by ironpaw
You'd think choosing an oil wouldn't be so difficult, however it seems that choice of oil has the possibly broadest range of opinions of all.
so Iamhe, after 5 years of trying different oils have you settled on one or still are you still experimenting?
There are still a couple I'd like to try out (the new Royal Purple HPS sounds interesting and my curiosity regarding the NEO oil can only lead to one result :rolleyes: ), but since I have over 220,000kms on my car I will be sticking with what I have found to "feel" the best - Motul 300v Chrono (10w40) with either HKS, Power Enterprise or Greddy magnetic oil filter with 10,000km changes.
As a side note, I am only going back to Motul because GW Sougi S6000 is discontinued.
Didn't I hear GW are doing a Sougi replacement? I'm pretty curious about NEO and ULX-110, heard great things about the ULX, but it's not fully synthetic.
Bad luck on the car Ironpaw... pics? Is it bad?
Cheers...
How bad?
I damaged mine early this year... made be sick to my stomach, but it was repaired and not replaced.
Probably a writeoff if it had to be replaced :P
Doesn't look like much in this pic, but the rear quarter was split right through leaving a hole roughly 20x5mm.
Yeah, heard that a while ago, but no further info.
How bad?
they said the closest to sougi 6 is sougi 5000. although is a semi synth few guys on here said they didnt notice a difference. althought i think its discontinued aswell lol
How bad?
OUCH
I don't think mine is that bad...damage is superficial mostly and the dent is mainly near the fuel cap area...
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
