Plus there is reasonably good access in behind for panel beating dolleys. Should be fairly straight forward to pull it out even without access to the rear. They would just weld a tab on and pull it out with one of those panel beating pull hammers. Looks pretty easy to fix.
dude pay cash
work out how much it will cost and if doing it through insurance and losing your no-claim bonus is cheaper in the long run. it might only be $500 now, but next year your premium might be $200 more when the job would have cost $600 in the first place.
being insurance they will bump up the price. pay cash and it will be cheaper
dude pay cash
OK so I'll hit up some places for a cash price....
Any Melbournians know of reputable panel beaters who will do a decent job?
Can someone tell me how to turn on the driving lights that are in the aero front bar on the nm35. I've tried both sets of switches on the light stalk and the 2 way toggle under the dash on the right hand side but nothing turns them on.
Cheers
Edited by slippylotion
try jetspeed in clayton...they do my mates' cars & put their own car in autosalon years ago...
don't get me wrong...some ppl who put their cars in autosalon go to DT panels for paint jobs and the result looks good enough to pass for autosalon entry...but beware that at times their work is not the best quality...
Hey guys I've asked earlier whats the on/off button on the lower dash next to bonet release latch???
So much to learn......
Dave :thumbsup:
Does it look aftermarket? Mine was blank until i installed my 'fun' switch in that position. You may have to drop that panel down & see where wires might go.
Q: what is the problem with running staggered width wheels/.tyres on an M35, i have had mixed opinions from GTR owners but was curious as to what you guys all thought.
our attezza screw up with different sizes and offsets. the GTR owners are able to if they pull the front shaft.
not sure how it stuffs up so i'de be keen to know aswell.
Rolling diameter I understand but width should really be a factor...
Cheers
the generally unplug the switch on the stalk. there is a small cutout at the back of the indicator stalk, remove and plug it back in.
if you have an aero model with the driving lights in the front bar, the 'I/II' switch next to the headlight height adjustment toggles between the bumper lights and the ones in the headlight unit.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
