M35 Info
Brazen
OK back on track.
Apparently my Power steering rack is weeping oil from the pinion seal.
I found this on some site:
Yes, you can replace just the "boots" on the end of a rack-and-pinion steering provided that the mechanism is not damaged. Unfortunately, the boot is just a dust cover and if the inner mechanism has started leaking there really isn't much that can be done without completely disassembling the mechanism. The fluid in a rack assembly is under pressure from the power steering pump and once it starts leaking the rack is pretty much "done".
Is this true?
Iain do u still have the steering rack from the wreck? does it really matter? I can see the fluids are a little low but I can just top it up I suppose..
yeah i have it, but at the moment its being used in a jig
as for people looking for M35 stuff, there is an entire forum for this exact thing. we have just been a little lax in creating the FAQs. but its there if you want to browse or add info to it
That forum is good, but there's information on here that isn't on there and vice versa. it's just another forum to visit...
OK back on track.
Is this true?
Not to keep it too on topic with M35 info; but you've just reminded me that we noticed this on my car a couple of months ago - and it was no worse many weeks after that iniital spotting (when we did my sway bars). A very slow weep. Fluid levels are still fine also. Would be interested to know the verdict on how much a new rack might fetch. Theres been a few M35s wrecked in the country, and several brought in for parting out - and yet we're still not seeing an abundance of parts avaliable >_<
Does anyone on here have the 3 nismo gauges that are in the center console in white???
Mike.
Dunc does if you want to check them out on a local car.
Like Josh said, they're pretty easy to get on IM. Always a set there.
Brad even fixed my boost sensor so it always works now too :worship:
'Always works'? He told me you have to solder it up every couple of months...
:yucky: Well, I'll let you know if it fails again - but for the time being, its working consistently :P
Cheers guys, i already have a set but as i have a Nismo dash i would love a set of white gauges to match :D
You could always get Jesse to get a price off Nissan Japan/Nismo?
Part number is 24845-RNM50-W and I think they used to be around 23,000yen
Here's a handy little Nismo parts page :)
http://hirano-tire.com/brand/nismo/paji272.htm
OR even better, just for to http://hirano-tire.com, click on "Search by logo"... and kiss your afternoon goodbye :banana:
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
