M35 Info
What turbos are on it? 356 American KW is possibly the best place to be if you want to use the car. Close the internet and hit up a twisty road and ignore all other opinions and see whether you have fun driving the car around.
Autotainment in Burswood did mine many years ago. But they have now moved to Vic park
Total miss. Just had to take back the water pump. Wrong part, it was for the older V series. Typical Nissan service/dealership 🙄
Not directly. I mean, there's nothing about what is happening at the wastegate itself that will generate smoke right there. But....if the car is overboosting and the ECU is dumping in fuel (because that's what they do from factory) then, yes, black smoke will result. It will also smoke if it is pinging its tits off too.
Can a jammed actuator cause black smoke on boost somehow?
