yeh radiator.
no thats for a G35 auto. you can run an external trans into the loop with the in built trans. hence no need for a thermostat, as the radiator will warm up the oil and keep it at running temp a lot quicker than an isolated trans cooler.
im getting Race Radiators to make mine custome. 3 way pass, in built trans cooler. and holds about 2 litres more.
will be ditching the trans cooler if this one seems good enough.
How much for the custom job?
install it yourself. its not that hard
scott? :rolleyes: lol yeh will probably have too.
Even still, it's not a bad price if you don't want an external oil cooler.
Actually one of these might fit a bit tidier in the engine bay: http://www.makcotran...m/708-4739.html
yh it isnt. but a mishimoto one will cost you 400 delivered.
I couldn't find any with the trans sooler. They all said "Suit Auto" but then you'd ask them if they had the trans cooler and they'd say that they dont.
yeh i didnt go to the extent of pm'ing them so you may be right
theres nothing wrong with having the bottom tank cut and have the trans cooler loop installed in one that doesnt have it from the factory. any radiator place should be able to do it
this is true, but for the total cost of getting theradiator, plus a tank installed you may aswell get a custom one.
if you guys are interested in radiators from RaceRadiators, I can get them to keep the design when they do mine? perhaps they'll deliver.
Yeah I'm interested in the Race Radiators thing, keep us posted. $700 isn't bad if the Koyo is going to cost Jase $600.
That said I'll probably still run past Tonkins and see what they say though.
when cam comes on he'll be able to tell you all about it. he already has one!
What about running a small cooler such as:
http://www.ebay.com....=item3cbaf1095d
or
http://www.ebay.com....=item19b30e6035
and just plumbing it before the radiator as previously suggested?
What size cooler are you guys running and where do you put it?
im running a PWR one for a Ford V8. imo those coolers are too small' and to be honest, i dont think the fluid will spend enough time in the cooler to physically cool.
Do you have a link? Where did you mount yours Aaron?
    • Still fast enough to have fun (kinda). Time for a modern turbo with a divided turbine housing and a proper twin scroll manifold. I think 400-450kW is a great place to be, provided it's all in before 4500 rpm.
    • i'm not at 600 though 😢 its 484hp (356kw) at the wheels..
    • Nice. 600ish HP is probably a nice place to be.
    • In the US the EPA has been going after shops that sold aftermarket ECU tuning software that allowed you to disable CELs for things like EGR, DPF, SCR, or TWC failure. They also went after shops for selling emissions delete equipment. Their logic is that all cars built for street use have this emissions equipment and you cannot do an after the fact conversion to an off-road vehicle not intended for street use. Cobb, Hondata, and similar companies have basically all revised their tuning software such that going forward you cannot suppress DTCs for emissions-critical systems, nor can you toggle systems on and off in the tune like EGR. You also cannot adjust OBD emissions monitoring logic. You can still tune these cars. But you have to do things the hard way, basically. For example Subaru FA20DITs used to delete the TGV system to get spare analog IO for a flex fuel sensor. EGR also has to be dramatically pared back because without the TGVs the stock EGR map causes bad misfires. Now instead they have to implement the flex fuel system as a CAN bus sensor instead. IMO, this is heavy-handed but the EPA in the US gave so much leeway for so long and the aftermarket relentlessly abused that leeway to the point that they could actually see the effects of all these emissions-deleted work trucks on their air quality monitoring for cities that haven't met Clean Air Act standards. It's one thing to have a few people deleting emissions on their weekend car that spends 9 months out of the year on jack stands. It's another thing entirely for entire fleets of tradies driving around 8 hours a day on deleted diesels that emit 1000x the emissions per mile of a compliant vehicle.
    • Hmmm. that's a tough one. There's a lot of history bundled up in that lot. Perhaps instead we can create a new pinned thread, called "Legacy Pinned Threads" and provide links to the these ones that will be unpinned in there. And maybe put the names of the pinned threads that are linked inside in the tags so they can seen from the outside? Or something like? I mean, it's half a step back towards having a more complicated forum structure, without actually having it. But there's a reason that heirarchical architectures exist. They are logical, and if executed properly, make it easy to find something without having any upfront knowledge of where it would be , and without using a search function.
