225/55r18
This is what my tyre placard states, the law states you cannot ecceed + or - 15mm of overall diameter of factory wheel/tyre combination.........otherwise speedo will be out by a certain %
So you could run r22x30x245 if your hektic and that
http://www.alloywheels.com/tyrecalc.asp
I'm actually looking for tyres for my 19x.9.5's (when they show).
Some good deals in 245/40 R19 - HSV front end tyres from what I'm told, same as what spoolin is running from memory. They are 1.5% out.. So at 100kmh reading you're doing 101.5kmh.
sweet, what offset do you have to run 9.5 wide? Mine are 9 inch wide and they are just legal, but will be getting new wheels when the funds allow it.
http://www.alloywhee...om/tyrecalc.asp
Oh noes! Does that mean I'm breaking-law.jpg?w=385&h=240:banana:
Like a Baws.
Edited by Daleo
This is what I run; it gives around 3% error (100km/h indicated= 97km/h actual) against my GPS. thumbsup.gif
My tyre size is exactly the same as yours Dale, & my speedo reads 7% fast at 100km/h by my GPS.....
I think the satellites need recalibration.
Lol, well I get a different speed going in two different directions on the same piece of road; so anything's possible...
Maybe if they bring the satellites a bit closer to the earth?:blink: They're miles too far away, IMO...
Edited by Daleo
Jase, if you're wanting to fit the valve body upgrade at the same time as dropping all the fluid, I can sell you mine, that rocked up today, and just order another one?
I'm not in a hurry, especially since I changed the trans fluid when I got the car, around 6 months ago. So if you're changing the trans fluid shortly, better off doing the shift kit at the same time.
Evidently I have come into this with my eyes shut. What is this valve body upgrade? Not the shift kit thing that everyone is talking about? I don't think I have the mechanical confidence to tackle a job like that.
Yep, that's it. Mine came yesterday. I love the sticker on the front, but I don't believe a word of it....
Yeh....not hard at all.....you just don't want to make an error. Things often come with labels like that.....also throw the distructions in the bin as they have a whole heap of useless info in them too!
Seriously
If you have mechanical knowledge it's a can do....if your struggling to do anything on your car mechanically don't attempt it!
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
