M35 Info
Brazen
It get's blocked up.
I've been lead to believe that if you clean it out, use good oil and service it regularly you should be fine.
To be safe, if you're running a standard turbo you can drill it out to 2mm, and if you're running a highflow you drill it to 3mm.
Scotty and Aaron are the experts, but that's what I've been lead to believe.
Any peeps on here interested in a wood trim interior for an M35? I only ask as I'm going to paint it all black unless someone wants to trade...
You can vinyl wrap the timber part of your dash and it looks pretty good.
I would just drill it out to 1.5 mm if you plan to keep the stock turbo, 2.5 mm if hou go for a bushed core.
The banjo threads into the block just in front of the passenger front drive shaft.
Great info, thanks guys. Might drill it out when I go to see my old man in a few weeks since he has a drill press. I don't even have a vice at the moment!
I don't suppose some one on here knows if the centre console on an M35 is interchangeable with the V unit? Chasing both the radio surround and lower gear stick surround. Figured if they are interchangeable it would make finding these parts a million times easier. :)
yes, they are both inter changable.
I saw one for sale on the V series forum
Well I've set mine to 360mm front and rear, this gives about 15mm gap between tyre and guard with my 245/45-18 tyres. I might drop it another 5mm but probably not worth the trouble. I like to leave 10mm gap so it doesn't get too many looks. With the aero front bar it just clears those cement stops in car parks. Its funny, when I look on the RAWS site and look up my car it shows the stock height (i think its listed wrong) and minimum height. It states unladen F and R 365mm and Minimum F and R 346mm. I had it at 345mm at one stage and its bloody low so I think the figures are wrong.
Edited by slippylotion
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
