Does anyone know if the standard M35 ECU can 'learn'?
After I changed the exhaust and dump I saw a massive increase in performance. On the dyno it looked to be 30kW and an extra 3PSI boost. Turbo starts to spool up now at around 2250rpm.
Then I fitted the pod, and on the Informeter saw I was running the injectors at 100% by about 6000rpm.
Then I fitted the HDI intercooler, and it seemed like it lost a bit, spooled up later, and was a bit more sluggish. I figured this was the lag introduced by having a bigger intercooler to fill.
Then I dumped the Valvoline oil, replaced it with Motul 300v, drove the car around 300km, and then let the car sit in the driveway for about 10 days.
Driving it on the weekend, it appears that the injectors are no longer hitting 100%, and the turbo is starting to spool at 2250. Sluggishness seems to have gone away, and it feels as good as it used to.
Would this be the ECU reacting to the mods, and relearning/retuning itself? Or would it be something else?
The HDI coolers have F all pressure drop so you wont notice any lag in boost unless you want to log a run and find it might 50rpm later lol
ECU's are gay and literally change a tune with a change of weather.
Does anyone know if all AR-X's come with the fixtures to buy and install the grate separating the backseats from the boot ie to stop my bloody dog from jumping over. From the pictures that have been sent to me it doesn't look like my AR-X has it standard.
If yes, does anyone want to sell me one.
Just so happens to be one on Yahoo Auctions at the moment.
Here is the Import Monster link
http://www.importmonster.com.au/view?url=http://page10.auctions.yahoo.co.jp/jp/auction/m89454506&thumb=http://f5.auctions.c.yimg.jp/img251.auctions.yahoo.co.jp/users/0/3/4/3/hotel_costes45_6-thumb-1319385762283631.jpg&title=M35
^That's a good price. Still, $375 delivered!
Also, pretty sure that all of the mounting "hardware" is included in all models. It should be up near the child restraining points. The lower mount is along the plastic trim along the bottom of the rear windows. There's little tabs that you press in and they pop out.
Edited by jasevr4
I could be tempted to part with mine if you need it. I only bought it a couple of weeks ago, but Northshore put the child restraint mounts in line with where the second rod goes, and apparently can't do anything about it. Otherwise I'll just store it under the floor till I need it.
Don't you use it as a divider for the back section rather the "seat to ceiling" position?
That's where mine always is. Stops the groceries from launching everywhere.
There are multiple configurations..
Those of you running some sort of digital gauges, what do you use to do so?
Does the M35 use OBDII? Can you get an accurate boost figure from this?
Greddy infometer seems to be the most common ....and we know it works....OBDII is correct!
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
