Most aggressive I've seen are Jase's, which I think are 19x9.5+22. Too angry for my liking, and the camber on the rear!
Thanks for the tip Alex. I'll go home and measure. Apparently 8.5+30 extends 34mm, which sounds fine. I can always try and test fit Saturday anyway.
Wheels I'm looking at are a good price, but they're pretty beat up. Looking at buying them and running them with decent tyres for 12 months, then getting them cleaned up and powdercoated. Bronze CE28s, should look good I think, but better when I get them powdercoated black! :devil:
My car isn't that low Jase! I don't know what you're talking about :whistling:
Looked mental when I saw it, especially with the stretched tyres!
BTW Found this: http://www.rimsntires.com/specs.jsp
Great tool to actually see what's going on. Very easy since Alex posted the standard wheel specs. Thanks!
I've found a really nicely designed rim that should work quite nicely on an M35 Stagea from Avant Garde. Different design to jasevr4's, these are the M368 model:
http://www.avantgardewheels.com/m368.php
For the Stagea they have one definite fitment option of 19x8.5+35, but also a 19x9.5+40 which I'm unsure would work. Outside clearance would be fairly aggressive, but unsure how the inside clearance would go as well as full lock-to-lock interference. The rim seen on the front of this Lexus shows the correct design (as opposed to the full concave version) of the 19x8.5+35.
Fronts: Avant Garde M368 in Dolphin Grey at 19x8.5+35
Nissan Australia, RHDJapan (send them an email, they'll list it and give you 5% discount), Jesse Streeter, Import Monster
Part numbers are (left to right design in the pic below);
G4911- AQ000
G4911- AQ010
G4911- AQ020
Going back a page there was mention of the iPod adaptor for the standard OEM deck. The Stagea we've just bought has the single DIN unit in place, but I have a question about the FM radio etc. Would it just be easier to just get a replacement head unit (HU), rather than hop up the factory HU with the iPod adaptor and frequency shifter?
You will have to dismantle your dash either way, so it is all up what you want.
If you just want to play your iPod, get the PA15-NIS adaptor. If you want to replace your entire head unit, might as well get something decent in there that does everything.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
