Probably not. Says "Owners Manual" not "Service manual". I'd have to have a look at whats in it before I'm prepared to buy one. I'm not sure I even need an owners manual.
Yep, original request to those guys was the full workshop manual back in 2008 (http://www.skylinesaustralia.com/forums/topic/232599-translated-workshop-manual-m35-c34/ )
Also, it states for 2001-2007 Stagea, but no mention of VQ35de? WTF?
I know the answer is here but I can't find it in a rush.
Attessa system fluid - same as the transmission?
Glad I'm not the only one that struggles to find anything.
90 pages of 'info' is more like 'comment on stuff about the M35.'
:rolleyes::ph34r:
To those who've rewired their fuel pump, where did you run the wiring from the battery into the cabin?
I was looking at it today and thinking the easiest way would be to drill a hole in the side of the duct where the cabin air filter is, and put a rubber grommet in. Most obvious place anyway...
Just slide it throug the main wiring grommet, behind the battery, then down the passenger side and along the back seat.
I've got so much stuff going thru there that I've left a permanent draw wire.
Thinking about how I'm getting the Fcon tuned, and more and more I'm thinking I should just go 98 for now. E85 isn't plentiful enough, 98 would just be easier.
If I go that way, I'm already changing the fuel pump and filter, and I've got the wideband.
Would I still need to change the injectors and/or fit a FPR for a 98 tune running the standard turbo?
I can't see you needing bigger injectors with the stock turbo. From what it seems, if you run ~20psi on stock turbo it will die quick ish.
If you tune with the stock boost (allowing extra 1-2psi for exhaust upgrade) it would need the rich factory set AFR leaned out a tad so the injectors should be fine.
Edited by slippylotion
^^^ what Paul said.
As soon as you go the full hog on you intake pipe you will have a top end lean problem with standard injectors & fuel pump. Andy got good results (AFRs richened up nicely) just by changing the fuel pump. My injectors are providing enough fuel just by changing fuel pressure regulator (stock pump). So if you planned to do either of those, & you've already got the pump, then you'll be fine.
I'm of the belief that our standard injectors can be sufficient up to maybe 250kw or more), given a bit of extra pressure to increase the flow. Check out 'injectors online' to see what sizes are used in various factory applications. eg according to that website, Gen III 5.7lt motor uses 260cc, XR6 (including turbo) use 295cc. M35s are 370cc, & when given extra pressure (there's a formula around somewhere) they can flow in the vicinity of 440cc/min.
^^^ what Paul said.
I would agree with you on the injectors Leon as even at 18PSI with my car my Wideband never gets over 10.8 unless under load going up a hill then is gets to 11.1. However the AFM is well and truly maxed giving readings of 5+...and I know my duty cycle is over 95% at times....I have also seen 100% quite a bit......I can live with that on the street as I am hardly ever up it.
However I would never track it without bigger injectors and the AFM clamped.
P.S. I think its awesome how the car has worked out its tune with the extra pressure at 14v with the Walbro on mine....it would be very interesting to try a set of 440cc injectors in the car with the standard fuel pump to see if/how it runs.
Well that's kind of my plan. Do pump and get tune with MAP sensor.
Will that cause an issue if I do some track work?
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
