Probably not. Says "Owners Manual" not "Service manual". I'd have to have a look at whats in it before I'm prepared to buy one. I'm not sure I even need an owners manual.
Yep, original request to those guys was the full workshop manual back in 2008 (http://www.skylinesaustralia.com/forums/topic/232599-translated-workshop-manual-m35-c34/ )
Also, it states for 2001-2007 Stagea, but no mention of VQ35de? WTF?
I know the answer is here but I can't find it in a rush.
Attessa system fluid - same as the transmission?
Glad I'm not the only one that struggles to find anything.
90 pages of 'info' is more like 'comment on stuff about the M35.'
:rolleyes::ph34r:
To those who've rewired their fuel pump, where did you run the wiring from the battery into the cabin?
I was looking at it today and thinking the easiest way would be to drill a hole in the side of the duct where the cabin air filter is, and put a rubber grommet in. Most obvious place anyway...
Just slide it throug the main wiring grommet, behind the battery, then down the passenger side and along the back seat.
I've got so much stuff going thru there that I've left a permanent draw wire.
Thinking about how I'm getting the Fcon tuned, and more and more I'm thinking I should just go 98 for now. E85 isn't plentiful enough, 98 would just be easier.
If I go that way, I'm already changing the fuel pump and filter, and I've got the wideband.
Would I still need to change the injectors and/or fit a FPR for a 98 tune running the standard turbo?
I can't see you needing bigger injectors with the stock turbo. From what it seems, if you run ~20psi on stock turbo it will die quick ish.
If you tune with the stock boost (allowing extra 1-2psi for exhaust upgrade) it would need the rich factory set AFR leaned out a tad so the injectors should be fine.
Edited by slippylotion
^^^ what Paul said.
As soon as you go the full hog on you intake pipe you will have a top end lean problem with standard injectors & fuel pump. Andy got good results (AFRs richened up nicely) just by changing the fuel pump. My injectors are providing enough fuel just by changing fuel pressure regulator (stock pump). So if you planned to do either of those, & you've already got the pump, then you'll be fine.
I'm of the belief that our standard injectors can be sufficient up to maybe 250kw or more), given a bit of extra pressure to increase the flow. Check out 'injectors online' to see what sizes are used in various factory applications. eg according to that website, Gen III 5.7lt motor uses 260cc, XR6 (including turbo) use 295cc. M35s are 370cc, & when given extra pressure (there's a formula around somewhere) they can flow in the vicinity of 440cc/min.
^^^ what Paul said.
I would agree with you on the injectors Leon as even at 18PSI with my car my Wideband never gets over 10.8 unless under load going up a hill then is gets to 11.1. However the AFM is well and truly maxed giving readings of 5+...and I know my duty cycle is over 95% at times....I have also seen 100% quite a bit......I can live with that on the street as I am hardly ever up it.
However I would never track it without bigger injectors and the AFM clamped.
P.S. I think its awesome how the car has worked out its tune with the extra pressure at 14v with the Walbro on mine....it would be very interesting to try a set of 440cc injectors in the car with the standard fuel pump to see if/how it runs.
Well that's kind of my plan. Do pump and get tune with MAP sensor.
Will that cause an issue if I do some track work?
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
