No I haven't swapped them yet. I just looked up the overall heights of the Kumho and Bridgestone, then measured the tread depths and it works out that the bridgestone is 9-10mm shorter in height than the Kumho. Would it be fair to assume this is to much of difference and causing it?
Even then if just that one tyre is replaced with a new ku31 that tyre will be around 4mm taller than the other 3. Surely Nissan has given enough margin to allow for something like this.
Edited by slippylotion
As much as this sounds funny, the same size in two different brands are not exactly the same size. Try pumping up or letting down the bridgestone and see if it has any effect. That is not a permanant solution obviously, but might give you some evidence.
Well I borrowed a set of factory wheels to see if that fixes the 4WD light issue I'm having. It didn't fix it. The s/hand Bridgestone they gave me measured up at 12mm shorter overall height than the ku31, thought that would be the problem but not looking like it. I
'm going to try and sus out the relay and see if that the problem.
How can I check if there is a code to check? Is it read out of the ECU or the attesa control module?
If you get desperate Paul let me know, and we can swap over the relay. Worked with Mike's, he tried pumps and all sorts and I think it was relay in the end. As soon as I put his relay in my car, I had a fault light and 2WD.
I might take you up on that offer Ryan. I can't find one locally to try it so that would be great if we can swap to test.
When is a convenient time to try it?
I believe its based in the ABS computer, not the engine ECU. I don't know of a manual way to see error codes, but I'd just hook up my cipher cable/laptop if you were in sydney.
Maybe one of the general code reader that mechanics have can read ABS too?
faaaaaaaaark what a long thread, packed full of great information, thanks to all the contributors.
However I did not see the actual story on how to eliminate the problem I'm having, which is, How to get the wagon to do a burnout! I have TCS off. it will light up a little when I launch, but stand stills are shit.
Also what exactly does the wire cut for transmission lock up do, I am considering wiring the brake and trans' mods to the TCS switch, to make it the FUN switch.
NZJP have told me they will have the workshop mannual ready in 3 months, they advertise on Trademe the NZ trader site.
there are a few options to be able to do burnouts
1. sell your stagea and get a commodore
2. grow up and dont try to do burnouts in car designed for AWD
commodores are not my friend, chocolate is!
I'm too old to grow up, and I am quite iresponsible
My car is RWD
oh and I'm a drifter, D1NZ
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
