Got a call from Nissan in Kirawee to supply new m/ cylinder ex Japan $470 bucks 3 weeks if in stock???
Don't thihk I'll go with especially when my rego is due this week as well.
Anyway lucky Lainy can help out (sorry mate no intention to give you a new nickname). Are you just Lain?
Thanks
Dave the wave
spell my name wrong again and the price goes up :P
try having a Dutch name and everyone who reads it pronounces it the English way, had it all my life where it gets to the point of not being bothered to explain it :P
Funny, Lambchops sounds pretty Aussie to me....
To quote Blazing Saddles: Sir, he specifically requested two "African Americans". Well, to tell the family secret, my grandmother was Dutch.
Edit: LOL @ SAU keeping me from sounding racist by auto changing the real word. Nice. I was just quoting btw.
Edited by Commsman
Is the double "u" sound like a oooo sound?
Leon ther s lots of auto corrects, most come out of wasteland. Like this one the sphincter of the universe
    • These are small points I should actually add to my original post. GKtech makes an extended slave line for this conversion. It's what I use, and it works well. You'll also need a CD009 slave cylinder.  S/R Chassis Z33/Z34 Conversion braided clutch line As for transmission sensors, you'll need to both extend the wiring and replace the connectors. I can't recall which is which, but one is your neutral switch and the other the reverse switch. As they are just switches, just test for continuity with your transmission in neutral or reverse to figure out which is which. Connectors:  VQ35 neutral Switch Connector | Wiring Specialties VQ35 Reverse Switch Connector | Wiring Specialties
    • I’ll try and see it could be the release bearing. As for the 4th gear grind maybe clutch doesn’t disengage properly cause it is slightly like very slightly hard to go into first could be due to the slab cylinder pin being short uni clutch is a twin plate.   Ive attached some assembly photos hopefully you can open the link and see maybe detect what’s wrong https://share.icloud.com/photos/0dc2YvW__Hl6jl-l2_0jejjpg https://share.icloud.com/photos/09e0jkWOK-vP48c1cfY6u3ViA https://share.icloud.com/photos/0b4rDmh5R7pK7fb1VtND73a3g https://share.icloud.com/photos/05eeUi_6dC4DVi80jOUYDgb0g https://share.icloud.com/photos/06335TgY1XxyIJal_wkdQLhzw
    • Yeah for sure that is peddle adjustment
    • What are your thoughts on this after having it for a while, worth getting?
    • Downshifts are harder on transmissions than upshifts, the input shaft naturally slows down once disconnected from the engine so the synchros aren't doing all the work. There's no "natural" tendency for an input shaft to increase RPM. Something is not right there, I don't have a great answer on what. You can try a dedicated GL4 75W90, I plan to switch to Motorcraft XT-M5-QS which is supposedly a very good 75W90 for NB Miatas which have a weirdly sensitive transmission from the factory. I would chase down why your clutch is making a hissing noise, that's not normal. It might be no big deal but in the absence of anything else to investigate I would look at that.
