M35 Info
Brazen
But why ony bank 1?
Thats the drivers side. Maybe because there is more pressure in bank two due to the return flow regulator being on that side (I think it is)?
Thats my 2c!
Thats my 2c!
But that would not explane why it threw up the fault code would it?
There is only one O2 sensor on the turbo, bank one. It is seeing a lean condition and can't add enough fuel to compensate.
If the o2 sensor was buggered it could cause this along with bad fuel economy, it needs to be checked for oscillation, otherwise you should do as Cam mentioned and check the filter and fuel pump.
After doing some googling some other things that popped up with this code were:
MAF, vac leak, PCV and the fuel filter as Cam said.
Scotty:
Fuel economy has been ok, well as good an an M35 can be. Have not seen a spike as such.
When you mention the O2 sensor do you mean the one on the dump yes? If it was this would it not effect both banks not just throw up an error on bank 1?
FYI: The issue came about from normal driving conditions in peak hour, not giving it much stick at all. When I got home I checked the fault code and then cleared it, ran the car for 5-10 min and it has yet to come backl.
Cheers.
There is only one o2 sensor (the one in the dump), bank one is it's name. The 3.5's have bank one and two as they run twin o2 sensors. If it doesn't come back you may be fine.
O2 sensors only have an 80,000k life so there is a good chance it needs changing anyway.
Genuine.
Have the books and also the de-reg papers that show the kms every time it was serviced and everytime it was registered. When I received it the kms were only at 29XXX.
Yeah I paid a bit more for it but got a very clean car, inside and out. I have seen other M35's, most other M35's I have seen have very dirty under carriage and engine bays. This is so clean you could eat off any surface, the previous owner must of only drove it once in a blue moon.
Cool, good to hear. Mine had genuine 59k on it with de reg paper and also was very clean under the car and engine bay. Only problem I found was a chocolate milk stain on the back seat from kids. When I removed the rear seat I found little girls hair clips and collector cards, so was deffinately the family wagon.
Hi everyone
a +38 offset will sit inside an ARX more? 18x8
if will, can I run bolt on spaces to make it sit flash?
Yes and yes (that is what spacers are mainly use for after all)
Hi everyone
The spacers you buy will have to be custom if the wheels you are fitting are stock. This is due to the hub centering ring on the hub and groove in the wheel being the same. Normally when running a bolt on spacer you are using aftermarket wheels which have a larger bore and that's what off the shelf spacers centering hub on the wheel side will allow for.
Hope that makes sence...
Actually, most of the off the shelf spacers will have both hub centering bore/rings the same size.
If you go different hub bore size on new wheels; it's normally up to you.
The thinnest custom spacer I've ever machined for a Nissan with hub centering rings on the outside, and matching bores on the inside is 8mm; anything below that, and the centering ring on the outside has no material behind it.
I've never seen an off the shelf spacer with centering bore/rings thinner than 10mm, so Rafael should be ok.
Edited by Daleo
What is the centre core measurement of m35?
I'm running +37 19's 8.5 wide.....pretty sure ford has the same centre core on the falcon...whatever that is.
Could you please point me in the direction of these as most places I've been to in Adelaide only stock ones with a 66.1 inner but a 73.1 or other outer meaning you can't space out stock wheels.
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
