M35 Info
Brazen
No bolts, just some small slots in the bottom.
I just helped Dave M35 with some info on fitting, I will just cut and paste my response.
Quote:
Yeh, I had a few issues too. The right hand twist fitting for the top I had to ditch the rubber, the pin was out a little too much. Looks like a manufacturing fault but it works ok.
The fiberglass had to be cut out around the radiator cap, not too much, just use a nice sharp blade so you can remove the cap easily. the fiberglass section must be further away on the G35.
The lower condenser slots are too wide like you said, but it doesn't seem to matter once the top bolts are done up. Just make sure the flat part sticking out stays above the slot then do the top bolts up.
The fan shroud is too short, I had to cut the edge off on the airbox side. Trial fit it before you put the rad in the car, you will see the section you need to remove.
the button with the ^^^^ on it you hold for a few seconds. it will defrost your mirrors and the wiperblades on the winscreen. handy feature if it gets cold where you are. mirrors for sure!
Just nicely IMO, if it clears the suspension on the inside.
Extends an extra 1mm than my wheels. But 12mm less room on the inside than stock
Best get a test fit, and consider tyres as well.
I really like this size converter Josh: http://www.rimsntires.com/specs.jsp
Chuck in your standard wheel size and offset, and your standard tyre wheel and offset, and then throw in your new wheel size and offset.
You can then muck around with tyre size until you get something reasonably common that puts the speedo about right.
FWIW I'm running 245/40 18s on my 18x8s, but 245/45 is the better fit.
235 or maybe a 245 if you can fit it?
I'm not good on the internal clearances.... but know that space is an issue a little more stretch will give you room.
Someone else know?
Try looking at G35 sedans with the same sized wheels.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
    • Here's the torque curves from the car I ramped boost up later in the rpm to allow a slightly wider useful power curve - the power curve is a bit weird shaped also thanks to the TVIS (or whatever they call it with the 4EFTE in this Starlet) which changes the volume of the intake manifold throughout the rpm range, but you can see that the green power curve actually holds later on with the extra boost... but looks almost more like the kind of thing you'd expect from a cam or exhaust change
