When these turbos let go , is it major and the car is undrivable or can you drive it home or to your prefered w/shop ?
cheers , Lindzz
I drove mine for over 150kms no worries, although I did keep it under 2500rpm.
I believe that Jetwreck drove his from Melbourne to Sydney when his turbo let go!
They are certainly "drivable", but it is a damn slow drive.
Drove mine to R E Customs today for "turbo out" - cruised at 80 - 90 on Eastlink no worries but took a while to get to this speed - sounds awful too......
Cam, i presume the Victorian 2 are yours and mine?
Once Turbo is out i will inspect at ATP (Advanced Turbo Performance) and talk over my options.
Indeed they are Jase.
Will be interested to hear what Kip has to say (relying on my memory to remember a name from 15months ago)
Hi,
Could someone please tell me what the ARX has in terms of diffs? I want to change the oil in them using Redline Shockproof Heavyweight, is this a good option? Or what is the part number for the nissan genuine diff oil.
Is there a front diff and rear diff? Or only a central diff?
How much L does/do they hold?
Also, is anyone willing to send me copies of the latest nissan fast? $15 dollars is yours if you can.
Cheers.
  • 1 month later...
any news with this GPS english version?? Im interested! but my Screen does not work....I think there is a plug missing from the Screen to the DVD unit (small connector plug comes from the loom out of the screen is not there...)
Is there any other way to get this working yet?
cheers
michael
I have a touch screen version in process currently using the OEM screen and I'm trialing it before I do a public release.
as for the original system translation - nup do not see that happening anytime soon.
  • 1 month later...
  • 3 weeks later...
FYI for all M35 owners:
ATTESA E-TS system is normally 0:100, but can split up to 50:50. SYNC mode is constant 20:80, but can also do 50:50. SNOW mode appears to be 50:50, but hard to tell, but it does NOT start in 2nd gear. Im guessing that there is a boost limit.
ATF 'D' is reccomended, 1.8L is required to fill the system.
Diffs require 1.4L each, and factory weight is 80W-90.
Engine requires 4.8L to the H mark, 4.0L to the L mark. factory weight is 5W-30. 10,000km/1 year is the required change period.
Factory boost is 12-12.8psi.
I would agree that is where the boost stabilizes to but I still claim to see 14psi on the initial application of throttle. I may have to go to the dyno to prove this.
So the ARX does have more boost than the RS-RX...... LOL.
Edited by andy65b
    • Any number of different ways. Have the coils draw sufficient current to provide contact wetting. Use different contacts in the switch, either by material or design, better suited to the low current drawn by a relay coil. Etc.
    • Hmm, how does the R34 manage to have headlight relays then without getting excessive carbon buildup on the headlight switch contacts?
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
