and where would one get this special blade and perhaps a part number
thanks
I normally renew the front pair, and cut down one of the old ones to use on the back; as Aaron says, pre bend it to suit the curve.
Plastic backed blades are shit; not flexible enough.
I only use the rubber ones with two stainless strips in them; over the counter at Repco is the only place I can find them anymore...
thanks
as Dale said. no special part, just cut it down to size.
i use the teflon stuff. had it for about a year now and it still works as if they were brand new!
Is the rear qtr panel on the M35 replacable? Or is it part of the whole body?
My wife cleaned out a brick fence while backing my car out...
Just wondering of the driver side rear qtr panel is replaceable.
Cheers...
EDIT: I think this is it?
http://translate.googleusercontent.com/translate_c?hl=en&rurl=translate.google.com&sl=ru&tl=en&u=http://www.megazip.ru/ru/auto/nissan/view/41/51/1900/58826&usg=ALkJrhiw7tWPbTVTQsKiBYj60Nr8xP4_Rw
Edited by ironpaw
Cheers...
fuuuuccck man.. even your light was gone.
i think they angle grind a section out if it cant be bog fixed. and weld a replacement and fix n paint.
Depending in the scale of the damage. You might be up for a new rear quarter.
Not a bolt on part; extends up to the roof at the C pillar, and all the way forward to the rear door...
Taken a pic?
yup, cut the spot welds and replace the panel.
if you were in sydney i can supply a 2nd hand rear quarter if you need it. but that will be gone pretty soon
As in someone is buying it?
I'm gonna just go thru insurance anyway...but want to see if they can just pay me the $$$ instead of having them repair it seeing its just panel damage. I know RACV allows this...
then I'll just hit up some cheap 2nd hand parts (already have tail light landed for $150) and get a decent import repairer to fit and fix it all.
Edited by ironpaw
You'd think choosing an oil wouldn't be so difficult, however it seems that choice of oil has the possibly broadest range of opinions of all.
so Iamhe, after 5 years of trying different oils have you settled on one or still are you still experimenting?
There are still a couple I'd like to try out (the new Royal Purple HPS sounds interesting and my curiosity regarding the NEO oil can only lead to one result :rolleyes: ), but since I have over 220,000kms on my car I will be sticking with what I have found to "feel" the best - Motul 300v Chrono (10w40) with either HKS, Power Enterprise or Greddy magnetic oil filter with 10,000km changes.
As a side note, I am only going back to Motul because GW Sougi S6000 is discontinued.
Didn't I hear GW are doing a Sougi replacement? I'm pretty curious about NEO and ULX-110, heard great things about the ULX, but it's not fully synthetic.
Bad luck on the car Ironpaw... pics? Is it bad?
Cheers...
How bad?
I damaged mine early this year... made be sick to my stomach, but it was repaired and not replaced.
Probably a writeoff if it had to be replaced :P
Doesn't look like much in this pic, but the rear quarter was split right through leaving a hole roughly 20x5mm.
Yeah, heard that a while ago, but no further info.
How bad?
they said the closest to sougi 6 is sougi 5000. although is a semi synth few guys on here said they didnt notice a difference. althought i think its discontinued aswell lol
How bad?
OUCH
I don't think mine is that bad...damage is superficial mostly and the dent is mainly near the fuel cap area...
