the generally unplug the switch on the stalk. there is a small cutout at the back of the indicator stalk, remove and plug it back in.
if you have an aero model with the driving lights in the front bar, the 'I/II' switch next to the headlight height adjustment toggles between the bumper lights and the ones in the headlight unit.
Thanks for that. The car hasn't been complied yet but I'll check that switch tomorrow. I did find today that the drivers side fog light wasn't plugged in. I also had a problem with none of the lhs indicators working at all. After a few hours checking everything I found that someone in Japan had cut a wire behind the drivers kick panel, I joined it back up and now all indicators are working. Very weird as to why they cut it.
Edited by slippylotion
ok so im picking up my RX Four (stock standard) yucky.gif from Edward Lee's in sydney with in the next week, after owning a W34 and loving it just curious to find out
1. Whats the best wheel combo to get (size and width)
2. is there a AUX 12V socket in the rear like on the W34?
will post up a some pic's when i pick her up from compliancing and registration
please please PLEASE have the car throughly checked by an INDEPENDANT inspection place. a mechanic, hell anyone that knows anything about those cars.
if possible, dont buy it from there
anyway, 18 as a minimum i would get in wheel size
no there is no 12v output in the boot, unless the dealer (in japan) has fitted one
I'm willing to bet that you have, or had, the mirror covers with the LED indicators.
When I picked mine up from having the alarm replaced, the indicators weren't working on the LHS except the LED ones, which flashed quickly. Found the problem was a wire behind the drivers kick panel had been cut by the scotch lock they used to connect the LEDs in the mirrors to the indicator lines.
Soldered up, all good! :thumbsup:
had a mate who is a mechanic go over it with a fine tooth comb he has worked with quite a few m35's in the past another mate of mine works at a body shop and can pick resprays really well, this one came through very well amazingly. very straight and mechanically no issues, was f.o.b when i spotted it while searching around the area. (arrived 30th june) still had quarantine stickers on her
what width wheel is recommended? looking at 9-10 inches
9.5 max...I don't know anyone running 10's on our cars...
Ideal sizes are 9+30 or 9.5+35 And I think it was 8.5+22 in the diameter your happy with. I found that the 9.5+30 only leaves about 3mm between rim and suspension link arm. I chose 9+30 as it sits the same in relation to the guard lip but has more room inside to the suspension arms.
if you wanted something abit "drift Spec"
you could probably go 9+25? should stick out about 5 mm, with some stretched tires and rolled guards. would look awesome! ive got 8+22 and i have about half an inch- 1 inch clearance to the guard which means i could space em out abit.
9+25 would look gooooood
you'd think so lol, but the plastic covers are just clipped into the stock fenders you have. so i cant run anymore offset than you.
although when i rolled my guards i did hack up the covers. and it came up great/
    • And half of them have been converted to turbos.
    • Welcome. This is not really true. We have a whole forum here just for the NA shitboxen. And they are not very different from the turbo shitboxen. Just weaker brakes and gearboxes, and no LSD, for the most part.
    • I'm pretty sure it has an 040 in it @Duncan Also reading up, that turbo should top out at 250 as you first thought. It will be interesting to see how early it chokes due to the changes in the head too
    • Yeah confirmed they are Nismo 555s, found the boxes in the spares with the factory injectors in. Yeah the AAC has been relocated to allow reuse of the factory brake booster line, and yes confirmed it has a 1 way valve in it. Unfortunately the one on the car is cracked, I'll need to replace it. Pretty sure I've got all the AAC plumbing correct in my previous post, but I am going to source some new fittings with 90o angles to help with the hose routing and also one really specific moulded shape for the AAC intake to cold start hose (will raid the back of our local repco when I get a chance and work out some combo that works) One of the big things I learned in the GTR is you need to be able to get your hands all around the bay when something goes wrong. I've done a bunch of re-routing now and it should be much more practical now. Also got the BOV mount re TIG-ed by the local engineering shop so that should be good to go now. Never got to the fuel pump because of some life stuff today, but will pull it to confirm it is suitable for 300rwkw when I get a chance
    • Hello everyone, I am from Malta and have recently bought myself a fully stock 1992 Nissan Skyline GTS. It has the RB20DE engine and thus is NA. Unfortunately, not a lot of information can be found online related to the GTS, unlike the information for GTS-T and GTR variants. Apart of the Skyline, I also got a 1984 Porsche 924 2.0l NA and a 2002 Renault Clio 1.5DCi for everyday use. Excited to be apart of the community and perhaps get better information on cars such as the GTS.
