Does anyone know if there is a replacement offset bush kit to correct camber fir the front upper control arms?
I Need to correct the front passenger arm as it now has 2deg neg camber from lowering it compared to the drivers side having 1.2deg neg.
that doesn't sound right but......is this what you are looking for though.
http://www.superpro.com.au/superpro-parts?id=SPF3297K
there is also the strut to chassis arm bush's that fix pull to the left.....these are one of the exchange sets I am offering...http://www.superpro.com.au/superpro-parts?id=SPF2848K
What is involved with putting the M35 into RWD mode?
Can you simply pull a fuse or does a wire need to be cut? Once the new wheels go on, in theory the space saver will be the wrong size for the Atessa system, so I figure I could pull the fuse and shouldn't have any problems.. correct?
incorrect. pull the front shaft out
Hard job?
The space saver would be trouble with the different wheels, wouldn't it? Think it would be alright to limp it to the next major town (could be 200km?) on a long drive to get the tyre fixed/replaced?
I would just drill it out to 1.5 mm if you plan to keep the stock turbo, 2.5 mm if hou go for a bushed core.
The banjo threads into the block just in front of the passenger front drive shaft.
Just following up on this, does anyone have suggestions for a banjo bolt that is already the right size? I don't have a drill press and it could be a while until I get to one. Seems like a sketchy thing to do without one (I don't even have a vice at the moment!)..
For the guys looking for more suspension adjustment on there M35:
http://infinitihelp.com/diy/gcoupe/projects/infiniti_g35_rear_camber_kit_installation.htm
I came across this vid of installation of rear arms in a G35, the only bit I found a little disturbing was when they decided to slot the rear arm hole in the cradle and use an offset washer... thoughts?
I believe there is an off set bush available but i have never seen anything like this...
http://infinitihelp....nstallation.htm
Considering the rear arm already uses an eccentric bolt set up; I don't really see the issue.
This method of adjustment is commonplace; many cars use it without issue, and the slotting that they do in this instance is to add MORE adjustment to the existing range available.thumbsup.gif
Does it really, I didn't know that... WOW that came of a little sarcastic.
The outside bolt is not correct? I only ask this as when i dropped the rear arm in mine I took out the bolt that attaches it to the hub on the outside is just a normal bolt, did not touch the inner one. Has the stock inner bold have much adjustment?
Mike.
Mike, this was the reason for my reply. Naturally, I assumed you hadn't looked at the subframe & seen the factory adjustment is exactly that. No sarcasm.thumbsup.gif
Mike.
No, the bolt in the hub is not eccentric, and it's actually bushed in the hub too. The back arm is a toe adjustment arm. For anything up to around 2" lowered the OEM eccentric will likely suffice.
Depending on how low you drop the car; the toe can end up being so far out that you cannot use the OEM eccentric bolt to adjust. This is normally at stupid "fitment' and "stance" brah ride heights.rolleyes.gif
For normal people; a more "eccentric" (more adjustment) eccentric will do. This is why they slot the hole in the subfame out a little more.
If that's not enough; you can move to the length adjustable arm; as per the dolts in that video who seem intent on using a power driver to undo every bolt, regardless of whether it saves any time, or is actually any easier.
With length adjustable arms; I have no idea why these guys feel the need to ALSO fit eccentric bolts; if it were me, I'd set the eccentric in the centre of its range, and finetune the arm length on a wheel aligner. Then you can make small + or - adjustments with the eccentric.
But hey; I don't use a power driver on pre loosened bolts either...cheers.gif
Edited by Daleo
Thanks bud, going to drop the stag in for a wheel alignment now... I wasn't going to as I didn't think there would be any adjustment in the back and if they couldn't adjust anything then I didn't want to waste any $$ for no reason.
Mike.
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
    • Just putting it out there, that's a decent list. You would be better off *not* doing *any* of that and buying someone else's modded car. Like mine. Or anybody else's. Yes it's lotto dependent and all this and that but that 70K (remember, double your guesses) could go elsewhere. Keep it stock, save your money, go lowball @Dose Pipe Sutututu :p
    • Does not mean what you think it means. The continual rising coefficient is the coefficient of friction that continues to rise with increasing temperature. Not "rising during a single stop", except inasmuch as the brakes should get hotter during a single stop. The RR would not be the best choice for a streeter. Yeah....no it's not. JAX would rummage around in the "shit pads we use for all shitboxen that come in here" and install those.
