M35 Info
Brazen
I would just drill it out to 1.5 mm if you plan to keep the stock turbo, 2.5 mm if hou go for a bushed core.
The banjo threads into the block just in front of the passenger front drive shaft.
Finally getting around to doing this today. Do I need to prime the turbo afterwards?
does anyone have a pic of where exactly the banjo is located.... say if i decide to keep the standard setup can i still drill it out to 2.5 mm just incase i decide later to go hi flow? will it effect the flow much??
You may blow the oil seals out or damage the bearings if you go too big on the stock setup. How much it will take? Who knows. Just clean it for now.
The banjo bolts into the block right behind the aircon pump and in front of the passenger driveshaft. It can be a pain to get out and watch you dont cross thread it when it goes back in.
excuse for a new one.
but yeh dont thread it lol
Hi everyone ,
Very new to this forum.....first post.
My name is Paul and I reside across the ditch in Hamilton New Zealand.Ive just purchased a 2001 250t rs four and are lovin it.Lots of great info on this site and I have been just about reading non stop every chance I can get.
What I would like to do is help the engine breath a little easier and it looks like the best way to go about this is to get rid of the standard dump pipe. To this end reading up here Scot is the man to see regarding this.
So Scott if you read this can you please tell me if you still are able to supply the turbo dump pipes or not as I would be very interested to purchase one.
Best regards Paul
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
