I don't get it. So the engine is the same as pre 2004 nm35s but it doesn't pass?
Can't they chuck in another huge cat in the exhaust to fix it?
It'd be a bit more complicated than that. Taking a guess, when a RAWS did the evidence report into the NM35, they have to do the crash testing/emissions testing. Maybe the NM35 doesn't pass whatever emissions regs were introduced in 2004. Thus no cars are allowed to be complied in that year.
Just a punt.
Just a punt.
you're on the money
Northshore is the one to call... although they have also offered to do compliance for J-Spec and possibly Prestige.
Thats correct, at the time I was importing my Pm35, Northshore was only going to comply 4 PM35's/year, for J-specs customers, myself being the 1st! (Thanks to Ben @ Northshore and Ben @ J-Spec for all their help). J-spec has been trying to get Northshore to comply cars for him for some time, and Northshore, understandably wants to protect his investment by limiting the number of plates he fits to cars which arent imported by him. Who knows what will happen in the future!
Maybe we'll see a PM35 at a cruise sometime soon then? :whistling:
What's the go with immobilizers on the NM35's? My insurance company stated to me that it must be fitted with an Australian standard immobilizer. My AR-X comes with an alarm, I assume it also has an immobilizer. Did most of you still install a separate immobilizer? I wouldn't be all that chuffed if my car was stolen only for insurance to claim I didn't have an "Australian standard Immobilizer.."
Any suggestions on the cheapest and most suitable turbo timer? are they absolutely necessary for this car?
Mine didn't come with an Immobiliser. I had a Cyclops one fitted...
Viper's aren't Australian Standards as far as I know. Go Auto Watch, Mongoose or Cyclops, and get it installed by someone who knows what they're doing.
You can also 'upgrade' the alarm to Australian standards if you want, might be the best option. I removed the factory alarm because it was playing up.
I'm pretty sure they are now....Viper I meant.
Turbo timers are a wank for modern cars with water cooled turbine housings.
I fitted a Viper and removed the factory gear.
I like turbo timers on modern cars (with water cooled turbo's) so when you track them, you can let it slowly cool down which allows the whole thing to cool down uniformly! :devil:
I think Viper have a unit which is, but the higher end stuff with the paging remotes, remote start, turbo timer, etc isn't.
AFAIK there's no Australian standard alarm with remote start and turbo timer.
Well i'm not tracking this, so i'll forgo the turbo timer which is fine by me. I'm nearly ready to buy a dump Scotty. Going to take it to a local exhaust shop for fitting, They charge $55 an hour, so i'm probably looking at about $200 yeh? 3-4 hours work?
I might call up my insurer for a list of Australian Standard immobilisers.
I don't have one in the stag, as I do the same thing. usually the 1-2 minute cool down drive is enough.
I use a turbo timer in the 1600. It's got a volt meter built in and can display speed in digital (handy for when the speedo tops out at 200km/h)! It also helps to reduce oil temp (even after the 1-2 minute cool down lap).
Most race guys usually let their car idle for a good 1-2 minutes even after they stop just to stabilize temperatures. $hit gets pretty hot, and 1-2 minutes warm down lap sometimes doesn't cut it.
I'm not really worried about the water cooled turbo. I'm more concerned about the aftermarket stainless dump pipe and exhaust system I have fitted, and other associated engine components requiring slow temperature differential.
Anyway, you guys do what you want on your cars, and I'll play on the safe side.
    • looking forward to your t56 swap man its a game changer if it works!
    • So, when are you trying the new GR86 or BRZ?
    • Uncle Duncan Yeap, FI Interchiller  Works well, normal IAT's cruising with the WTA only went from 50°c+ to 25-30°c with the interchiller  Before, when on it hard, the IAT would see 80-90°c, now, the highest has been was around 38°c IIRC IAT is measured under the blower hat I recommend it for the street or strip where your only on it hard for 10 or so seconds, but it wouldn't be efficient for sustained track use as it would heat soak from the AC turning off or whatever it does during WOT to protect the compressor It really needs the AC running for it to not heat soak and keep the WTA coolant chilled My WTA coolant temps when just cruising is around 2°c
    • Hey Mark...sorry to interrupt your career change to hair dressing... but...did you ever fit the interchiller to the commodore, and if so how was it? And, who made it?
    • I've been pondering this, I really enjoy the convertible thing, for me, it's like riding a motorbike, without all the issue of riding a motorbike, mainly, my old sore arthritic joints getting beaten up, and, being able to do it in shorts and a T-shirt and not needing a helmet and all the other gear required, especially like wearing jackets and pants in the summer, or needing 6 layers of cloths in the winter, or not having wet weather gear handy when your 100km away from home on the bike when it decides to start raining As for the hard top and its Coupe look, whilst I do lose all that open top feeling that I really enjoy, from my experience with the NB with a detachable hard top, the cabin is a much nicer place to be, the difference in noise for one, a hard top quietens down the interior, alot, with the soft top up or down it's pretty noisy, which, after 5 or so hours, can get tiring But, as you stated, the detachable hard top totally changes the look of the car, in a really good way, and for me, the look of a detachable hard top is so much better than the PRHT which looks more like a after thought with its weird bulbous rear roof line For me, the minimal effort of putting in on, or storing it after removing it, is well worth the time and effort for the look alone And yes, I'm sure the next owner will be grateful for it as well.......
