That is a pretty accurate review, of a standard M35. Good thing is there's some pretty cheap mods that will address most of the 'bad' points.
I quite like the look of the back of mine now that I've made some changes, although I wasn't very fussed prior to that.
So for reference's sake, the Informeter is saying that my max coolant temperature is 98 degrees in my car. That is with a Koyo full alloy radiator to suit a V35. I'm pretty sure that before I cleared it, Dunc's max temp was 103 degrees celcius. Not sure if it helps anyone but just thought I'd add it anyway.
Now to figure out how to get my air cond thermo fan to start working. :rolleyes:
Interesting review.
If you do the dump pipe and exhaust, and the brake wire cut mod, I'd be interested to see this review again after...
All these will still not get rid of the abysmal throttle response....It might help a bit but its still shit slow off the line...
Thats the issue with going highflow, boost comes on later and our cars have bugger all low down power. (Mainly due to the low compression.) Mine seems to take off much better off boost with the larger rear housing on the turbo, as there is less exhaust restriction. Throttle response is great once you are on boost.
Well, yeah, once your on boost its sweet. Its the 0-30 kph I'm referring to...
So I know what Iain thinks, but what do others think about the "Nissan Sports Muffler". Would a dump and decat pipe make much of a difference to performance with the standard "rear pipe" attached?
it would......any improvement over the standard system would be better......but!!!!
I don't know how much restriction is it but you'll need the dump pipe just to get rid of that cat. I'd keep a cat in the midpipe but with the Nissan Sports Muffler do you still have the box of baffles in the middle of the car? If so a midpipe would make a huge difference!
I know where you can get all that sorted too... :whistling:
Scott put one of his dump pipes on mine. I could feel a little difference, but not a lot
This is interesting. A lot of people on here have claimed a dump pipe will significantly increase performance. Its all subjective I suppose.
My car is standard at the moment, I'm 95% sure i'm going to get Scotty to fabricate a dump pipe for me and AM Performance a Cat-back. I'm going to do a 0-100 before and after. Does anyone know of an App for Android to test this? I've got Galaxy S2, so something to use the inbuilt GPS I assume.
I think there's a thread about the SS Wagon vs M35 somewhere on here. Well last night I burnt off a new Calais but i'm 99.99% sure it was the SiDi v6 version. Still, it was a comfortable 'win.'
I'd assume an m35 with a turbo-back (and nothing else) would match an SS. Where I live the air is crisp and I think the turbo works a lot better than anywhere else in Australia.
I'd also be interested to know the weight difference (if any) between a standard exhaust system and a typical aftermarket one.
Edited by Drogba
I don't have the box of baffles. It's either been replaced with a resonator or came with one from factory. The welds look way to clean to be a modification IMO, but maybe I'm wrong..
Actually, Dunc has the same muffler - does yours have the box of baffles?
a VE SS would comfortably beat a stock M35...even if you've got a whole TBE system...
MEH!
My CD player won't eject a CD and i'm getting 'CD Err F0.' I reckon it's just cheaper to sort out a connection to my ipod. Is there an AUX at the back of the player or do I need to buy an adaptor, similar to the V35's.
Oh and I didn't realise VE SS did the 100 in only 5.5secs, dayyamm
Edited by Drogba
    • As an ex-skyline owner Going off how these things are now "modern classics", I would keep the twins and just "refresh" bits that are required for reliable power and have a car you can take out for a cruise whenever you get the itch As a idiot who cannot leave things alone Going deep into the "rabbit hole" is a easy thing to do, as previously mentioned, once you start it becomes a slippery slope, wirh lots of supporting mods, and possibly rebuilds, and unless you have a bottomless pit of funds, the car can spend most of its life sitting in the garage,  broken, waiting for parts, or building more funds For a classic like a R32 GTR Basically, a reliable OEM+ refresh, that isn't a broken garage queen, is alot better than a car that you build, then break, then fix, then break again And it isn't just the engine you need to worry about, these beasties are getting on in age, and all parts are getting, and have got, expensive, the days of picking up cheap replacement engines and other driveline parts are well and truly over The funds not spent on going a single with quality parts, and with all the other other bits required to make it happen, could be spent on refreshing alot of other parts A wise man once said "If you cannot afford 2 GTR's, you cannot afford 1", I also believe he said this about 20 years ago when you could pick up a clean R32 GTR up for around $20k My advice for a R32 GTR (the one and only true Godzilla in my mind) is to think holistically about the whole car, the body, the power train, the suspension, the brakes, and the driveline SAU is a wealth of knowledge with decades of Skyline experience,  from stock, to OEM+, to modified to varying degrees, to full on or weekend or dedicated racecars, as well as full on money pits that rarely leave their garage Treat the old girl nice and give her what she deserves, you are a lucky man to own such a classic car
    • For that price you could buy the hypergear turbo (big fan as I run one) and the Haltech ECU..
    • +1 for the Elite 2500. Get some new knock sensors while you are at it (pretty cheap), look up the TAARKS Nissan knock sensor kit. You may also want to get new coils (R35gtr) while your at it (assuming your on stock ones), as they are a liability. Mine started right up and idled fine on the base map. Also go MAP over MAF, as said above, Haltech make this super simple right out the box. Another fanboy of DBW here, Outsider Garage from your neck of the woods make some nice conversion gear for the R33 (that’s where I got some of my gear from).
    • Nvm ignore this I read it wrong
