MEH!
My CD player won't eject a CD and i'm getting 'CD Err F0.' I reckon it's just cheaper to sort out a connection to my ipod. Is there an AUX at the back of the player or do I need to buy an adaptor, similar to the V35's.
Oh and I didn't realise VE SS did the 100 in only 5.5secs, dayyamm
There are heaps of threads about "fixing" the CD error, have a search in here or in the V35 section.
For an iPod connection to the OEM head unit, the USA Spec PA15-NIS is what you'd be after for simple plug and play (although you will need to get behind the headunit)
http://usaspec.com/product.php?ProductID=30&forceShowProduct=1
http://usaspec.com/p...ceShowProduct=1
I use that same USA Spec set up. Awesome sound quality and VERY easy to fit and set up. Cost was under $150 delivered from the US. It also has a spare audio input if you want to hook something else to it and also charges the iPhone.
scchwweet, thanks for link.
I ordered mine here. Mine was a tad cheaper as the dollar was higher at the time
http://www.ebay.com.au/itm/USA-SPEC-PA15-NIS-CAR-STEREO-NISSAN-INFINITI-IPOD-AUDIO-ADAPTOR-NEW-/400268286077?pt=LH_DefaultDomain_0&hash=item5d31d9587d#ht_3202wt_1378
Edited by slippylotion
Hi All
Had a strange idling problem with my ARX - I was driving the car for good 2 hours then pulled over
strangely the car idles so low where it feels like its going to die. Any thoughts?
Also, can anyone PM me service details for each KMS ie: 10,000kms service and so fort
Thanks everyone
Cheers!!!!
So that will fit the non bose system? Does an installation manual come with it?
Yep fits the single DIN factory deck. Comes with instructions although its very easy to install. All you need to do is name the playlists on your iPhone with Nissan in them.
I run:
Nissan 1 - artists
Nissan 2 - albums
Nissan 3 - all songs
Nissan 4 - blank
Nissan 5 - blank
Nissan 6 - blank
You can set them how you like but you need to name them 1-6 with Nissan.
Nissan 5 allow direct iPhone control rather than control from the deck. If in 1-3 playlists you can jump song/albums/artist via the 1-6 buttons on the head unit.
Overall its a great unit to connect your iPhone/ipod.
Import monster/ streeter?
On another note, Im looking at wheels at the moment. Im not happy with the flap in the sidewall I currently have on one, especially considering I have a drive to Melbourne coming up. Not replacing tyres on the 17s, rather move to 18s.
Looking at either 350z track 18x8+30 or CE28S 18x8.5+30.
Ive seen pics of the 350z track fitment and it looks good. Ive also seen people with 19x8.5+22 and it looks good. Would i be right in thinking 18x8.5+30 will be a good fit?
Not sure if you remember how mine sit but they are 9+30 and I wouldn't go any lesser than that. I think a 8.5+30 will sit in the guard too far.
I'm running +37 by 8.5 and they don't stick in to far.....you can always run some spacers if you want more track!
No the 8.5 will sit out another 6mm and in another 6mm. To fill the guards I would go either a 9+30 or 8.5+22 or if you want them Out the guard a little go for 9+25. These sizes keep good clearance inside to the suspension arm.
PM me your number and I'll send you a pic of how mine sit, can't upload on here as I accidentally killed my MacBook yesterday ?
Well the 350Z Track wheels look ok, based on the pics Ironpaw has posted:
So if the 8.5 is going to give me another 6mm that sounds fine. I don't need to fill the guards right up, and I don't really want them out the guards.
Just wanted to make sure they'd clear, and try and get an idea of how the 18x8.5+30 would look compared to the 350Z 18x8+30, because I knew there were pics online of the 350Z wheels. Might give the guy a call and try and drop round and test fit on the weekend.
Cheers for the help, PM sent.
All depends on how much low you have.
The moar low, the bigger offset you can tuck in- to a point. If you dropped Ironpaws car 1 inch all round, the wheels would be tucked in and IMO wouldn't look great.
Just type in "wheel offset calculator" into Google, and that will tell you how much it will change by. Stock is 17x7 +45. Go from there. We have seen up to 18x9.5 +30... or maybe even a tougher offset on M35s.
Yep, your car is pretty damn low from memory Ryan! I'd be thinking you'll need 10mm spacers at a minimum to make them look even remotely close to "fitment".
    • So recently at the track had experienced a loss of throttle after a period of WOT after installing the emtron ecu, recently did some logging to troubleshoot the issue and found the ECU was cutting due to a low oil pressure issue. Going over the log can see that while accelerating at 4k rpm will see 100 PSI of pressure and holding steady at that level until getting off the throttle which then after can see as low as 25 PSI at 3-4k rpm and will recover back to a normal level after that.   Wondering if anyone has an idea what could be the cause as it just feels abit strange and i dont feel like it could be a sensor issues just due to it clearly sitting at a good pressure until off throttle, in the attached can see a 3rd and 4th gear pull but can even perform great through 3 and 4 gears of WOT but still once off throttle and getting back on it will see pressure drop.
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
    • Cut sump up and extend. Win win 😂
    • All, What's the recommended torque for the 1/2 head studs for RB30 twin cam conversion with RB26 head?
