How is the reception ? I also noticed some very slight noise, was thinking to clean that up with a 'noise filter' on the power wires. Ive got 2 from an old pioneer analogue car tv tuner which should do the job. Probably these are a must for all add-on audio and video receivers.
Simon
Hi guys , I would probably be interested in the GPS mods if they go ahead , the english discs didnt work in my s2 gps, but i got the TV going good ,just had a slight hickup with the aerial amps.
https://www.sau.com.au/forums/topic/185569-m35-info/page/9/#findComment-3727216
Simon
I have found the reception great, You get some clipping/pausing in the signal rarely but overall it has worked much better than expected. I have not you had a chance to see whhat sort of range I get as I have only driven in the CBD.
https://www.sau.com.au/forums/topic/185569-m35-info/page/9/#findComment-3727742
I've found the watchable range in Brisbane from transmitters to be around 40 km with the factory aerials.
https://www.sau.com.au/forums/topic/185569-m35-info/page/9/#findComment-3727948
had you tried changing the way the factory aerials are wired, eg connecting one of the side windows to the one of the back windows where they connect to the 2 F-Connectors on the tuner ?
https://www.sau.com.au/forums/topic/185569-m35-info/page/9/#findComment-3736144
Yeah, that's the way I have it wired, (back+side) x 2. I think thats what I described in my DIY for the C34. Is that how you went ?
https://www.sau.com.au/forums/topic/185569-m35-info/page/9/#findComment-3736305
Im not sure which wire was which side, from what i can remember i tied the same colors together as you described. On my car the the for aerial wires were two sets of pairs (double coax) the colors corresponded to an f-connector on each set of doubles.
How did you determine what color aerial was either side or rear ?
https://www.sau.com.au/forums/topic/185569-m35-info/page/9/#findComment-3736739
I ended up following the coax to the amps to determine sides and rears, M35 might use different colours. The C34 has 2 amplifiers, one in boot(2 rears) and one on rear left upper pillar(2 sides). The amps have the colours on the coax as well.
probably just trace back coax to the amps, should give you a good indication depending on location of amps.
I would think that each double coax corresponds to an amp, one back and one side, therefore you would have to split each to make one f-connector ?
https://www.sau.com.au/forums/topic/185569-m35-info/page/9/#findComment-3736747
Well I checked the connections and wouldn't you know I had the sides connected and the rears connected together. So I rewired it today (front and sides together) and will check out the reception when I go out.
The M35 is the same each double coax connection goes to an amp with a power wire in between, the signal conductors are red and white on each set so I connected the reds together and the whites together.
I will check if the result is any better this way and get back to you.
https://www.sau.com.au/forums/topic/185569-m35-info/page/9/#findComment-3736871
today my driver side window stopped working. of course it was down at the time. i took the door apart and gave the window motor a good tap. and it worked enough to get it closed. any ideas on what the problem is or has anyone had a problem like this before.
https://www.sau.com.au/forums/topic/185569-m35-info/page/9/#findComment-3748541
Sorry, but it is illegal. We can't distribute this software because we haven't copyright for it.
If someone can reach Andrey - we can teach him how to update firmware.
hello, Fedor. I live in Russia, and own X-trail produced in Japan. Could you tell me how to update firmware for Xanavi DVD nav sat, in order to have english language? I do not need any maps, just to have english language. Please write: mailto:[email protected]
https://www.sau.com.au/forums/topic/185569-m35-info/page/9/#findComment-3750586
Did anyone know what for there's A/P symbol on the indcator panel (right of the clocks). Japanese said that it's indicator, that it flash (or lit up) when it's time to remove filter. And may be anyone know is it possible to install ION system? Because now I use Denso ION, but it takes place...
rusdima, U better e-mail them on the xanavi.ru
Edited by Ayugene
https://www.sau.com.au/forums/topic/185569-m35-info/page/9/#findComment-3750613
Sorry to ask a stupid question.....but what does this thing do?
https://www.sau.com.au/forums/topic/185569-m35-info/page/9/#findComment-3752160
*cough* BS *cough*
no but seriously.. there's no evidence that ionising the air does anything more than you can achieve by scratching your balls while facing north with one arm out the window
That's what I'm doing wrong...
https://www.sau.com.au/forums/topic/185569-m35-info/page/9/#findComment-3757985
hey guys does anyone know what size rims will fit an m35. i'm interested in some 18's or 19's. anyone know what widths will fit and what offsets are needed.
i got no money for them yet but just trying to suss out what will fit so i can purchase when the cash comes in.
https://www.sau.com.au/forums/topic/185569-m35-info/page/9/#findComment-3758666
Have a look at this link. This has pictures of an ARX with 20inch rims.
http://www.skylinesaustralia.com/forums/M3....html&st=20
https://www.sau.com.au/forums/topic/185569-m35-info/page/9/#findComment-3758837
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
