Did anyone else on the waiting list get an email from JPNZ about the workshop manual?
They're about to start work, want a $50 deposit, manual will cost $150NZ and will take 2 months.
Anyone keen?
i got an email, again im not puting a deposit becouse from all their other work im unsure what exactly will be translated, and what is including, and the quality of the job, if its done well, im willing to pay 150 but not going to pay 50 sight unseen for somthing that may be worthless
Yeah, agreed.
I think it's taking the piss a bit to wait this long with nothing, then expect 33% upfront with no guarantee of the content, or quality.
Their previous reputation certainly doesn't reassure me.
  • 3 weeks later...
Hey Josh,
I have little luck with search also - it appears I suck at the internet, lol.
Do you have an oil leak from the drivers' side? So far I've not heard of anyone with that issue. I'm about to pull the plenum & passenger side valve cover off mine to 'fix' the leak for the third time.
13270AL612 – Passenger side valve cover gasket
13270AQ800 – Driver side valve cover gasket
Edit: Too slow (got distracted) - now there is more results for the search function :)
Edited by Commsman
Well I hope you don't have the same problem as me then. My plastic cover is flexing slightly as it's tensioned down, so that the gasket isn't compressed enough in the middle (between two bolts positions) to stop oil leaking out. I'm going to have to take more drastic measures to fix it.
I guess what I'm saying is 'if it aint leaking, don't fix it", lol.
Ok guys I have a bit of an 4WD problem with my M35. Last week I had the tyres flipped on the rims and while doing it the tyre centre split the side wall of one tyre (their fault and trying to get them to replace it at their cost) Now they fitted a temporary s/hand tyre in the same 245/45-18 size but its a Bridgestone instead of the Kumho ku31 it had.
The Bridgestone has 2mm less tread depth than the KU31. Its only been on for a couple days and now the car has started randomly throwing up the 4WD warning light.
Could the attesa system be that picky that the s/hand bridgestone is causing the problem? I checked the fluid level and its fine, car drives as normal but when the lights on if I select syncro mode it won't drive the front wheels at all. If I turn the car off and restart it sometimes the light will not appear and then if I select syncro mode it works as normal.
Any help is appreciated as Im worried now that if they replace that 1 tyre with a new KU31, that tyre will be 2mm more tread depth than they other 3 and still cause this problem, so I may need to try and get another tyre replace so both tyres on the same axel are the same rolling diameter.
So does anyone know exactly what veriance Nissan have given the attesa system for rolling diameter?
    • Interesting.  Great info. thank you.  Give a few days to get that name plate.  I have a busy life most weeks.  I will be in touch.
    • Strange your posting about this being an issue. Move the harness or change your wheels or run more camber etc. Have the thing not touch the thing so it doesn't destroy the thing.  Short answer, no. Slightly longer answer, the factory fuel gauge is measuring resistance. You need to wire in the FPG fuel level sender into the original factory fuel level sender wiring.  I drew you a picture to explain this one The factory strainer is quite long, reaching down into the bottom of the tank. Safe bet your aftermarket fuel pump has a little baby sized strainer that probably doesn't even point down towards the bottom of the thank.  Solution, move the pump lower down in the tank, or fit a longer strainer, or do both. I did both, I've run my tank down to 5L remaining and the car still drove fine.
    • S2/3 GT-R is the same as S2 GTS-t The SRS airbags module in under the centre console. The S1/S1.5 GTS-t and S1 GT-R had the module built into the steering wheel. FWIW, I have a S3 GT-R wheel in my S2 GTS-t shit box. Same airbag plug, airbag light goes on then off, meaning all systems are go. S3 GT-R has red stitching, that's about it.
    • Dumb question, but why would it matter if the wheel came off a car with hicas or not?
    • Hey to anyone that reads this, long time lurker first time posting, sorry if it’s been answered before but I’ve been looking for nearly a year now for answers. ive got a 25det neo in an r32 that works awesome when it works (made 500whp on 21psi) but works 45% of the time, 1st issue there’s a harness that runs under the passengers side front fender that my tire keeps rubbing through and one wire seems to power the fuel pump even though I’ve done the relay “mod” some people like to call it, and when it does rub through it kills the car, yes next time I’m with the car I want to take the fender off and try tuck the harness well out of the way but I’d also like to try and by pass this mysterious wire as well lol, also wouldn’t mind getting power from the alternator as I’ve read it supplies the pump with 13v ? But no idea where to run the power wire too. 2nd issue, when replacing my fuel pump and fuel hanger I managed to break the factory fuel level sender leaving me with no fuel gauge, I’d like to buy the fpg fuel level sender for r32/s13 but the plug it comes with confuses me, I’ve got a detschwerks x1 fuel hanger which has light + pump - level + pump + and a ground, I’m no auto sparky but I’m wondering if I can cut the plug off the fuel level sender and wire the negative to the pump negative and wire the positive to the level positive to get a fuel gauge back ?🥴 3rd and final issue, the reason I want a fuel gauge is because whenever it’s below half a tank, it fuel starves like crazy and runs like a bag of shit even without doing a pull or sloshing the fuel round in the tank, I’d also like to fix this but have no idea what’s causing it, I’ve got a dw420 and a dead head fuel setup meaning the fuel is regulated before it gets to the engine, my only theory is that the return line is to close to the pickup on the pump and when it’s at half a tank the return line is causing the pump to cavitate enough to cause fuel pressure issues, that or the pump isn’t low enough in the tank which I would find strange considering I can’t find a single thing online about it, also if ya wondering how I figured out it happens at half a tank without a fuel gauge, I waited until it started happening and went and filled up and the car took exactly 30 litres every time I tested it, if ya managed to read through this mess I appreciate that and any recommendations , cheers
